Torque spec? Knock sensor.
Old Mar 11, 2008 | 08:03 PM
enkeivette's Avatar
enkeivette
Default Torque spec? Knock sensor.
What is the torque spec for a knock sensor on a roller engine? Also which year C4s had roller lifters?
Old Mar 12, 2008 | 02:02 AM
staugur's Avatar
staugur
14ft/lbs,late '86 onwards.
Old Mar 12, 2008 | 05:47 AM
Can86Z51's Avatar
Can86Z51
No factory 86 Vettes(late or not) had roller lifters/cams - those started only with 87's and up!
Old Mar 12, 2008 | 11:20 AM
staugur's Avatar
staugur
Well mines an '87 with a build date of october '86 and it's a full roller motor so explain that.
Old Mar 12, 2008 | 11:57 AM
CFI-EFI's Avatar
CFI-EFI
You already explained it. Your car isn't a late '86. As you said, it is an '87. Also, no L98s are "a full roller motor". "Full" in the vernacular includes rocker arms. It didn't happen.
RACE ON!!!
Old Mar 12, 2008 | 12:27 PM
Can86Z51's Avatar
Can86Z51
RACE ON!!!
Exactly!! Sheesh!!
Old Mar 12, 2008 | 02:56 PM
enkeivette's Avatar
enkeivette
RACE ON!!!
I didn't even think about asking which blocks were full roller motors. Thanks! Good thing I didn't buy the sensor yesterday.
And the 87 knock sensor should have the same thread pattern as the 85 and 86 sensors right? Basically I'm installing a knock sensor/ knocklite in my 80-85 carbureted block. But I have roller rockers and the retrofit roller lifters, so I want a sensor designed for the roller noise profile. I'm afraid to run more than 28 degrees of advance with boost till I get the knocklite installed.
Old Mar 12, 2008 | 09:12 PM
CFI-EFI's Avatar
CFI-EFI
As pointed out above... NONE. There have been no full roller L98 motors. The knock sensors screw into the block water jacket drain plug holes. I doubt they have changed from the 3/8" NPT since the SBC was born in 1955.
RACE ON!!!
Old Mar 13, 2008 | 12:59 AM
enkeivette's Avatar
enkeivette
The 87 sensor was actually $10 cheaper than the 86 sensor, go figure.
To Torque spec? Knock sensor.
