1996...Gonna order the hyper-tech monday to control the fans....Got a 180 stat. now. Do I need to get the 160??? Will I also need to download there program for the 160??? Or just use the 180 and use hypertech just for fans....Also, whats a good on and off temp. setting for the 180 and the 160..Thanks man ...all of you are a big help in this forum...hats off!!!!!1 :cheers:
You can't just "set" the fans at what you want to. There are 2 choices in the HPP. You can use a 160 or a 180 stat. It will ask which you have to program it for that stat.
It seems to me that there are only 2 choices regarding the fans. YES or NO. Yes means you get the new program which is on at 172 F and off at 165 F. (I did not like this setting since I drive my car long distances and there is no point for having the fan run constantly. This would however be helpful at the drag strip.) No means you keep the stock fan program.
For those who drive their cars on a regular basis it may be better to use a manual fan switch so you could turn it on when ever you get stuck in traffic, well before the temperature reaches 225 F. I have never seen an aftermarket fan switch wiring harness kit for 96's as I have seen for 95's and older. I assume this is because of OBDII on the 96's. Does anyone know how to do a manual fan switch on a 96?
FrankLT4CE
