Hvac problems
Old Mar 12, 2008 | 10:00 AM
LSCHMIDT's Avatar
LSCHMIDT
Default Hvac problems
The control flaps for the vents on my '94 coupe are not working correctly. I can't get the upper vents to work. Everything flows to the floor. Is this a common problem?
Old Mar 12, 2008 | 12:43 PM
runner140*'s Avatar
runner140*
Take a look or purchase a FSM (factory service manual). Sounds like HVAC module. The rubber hoses going to it have deteriorated. Simple job but tough getting to it.
Its a common problem.
Old Mar 13, 2008 | 11:22 AM
LSCHMIDT's Avatar
LSCHMIDT
Thanks, I have the manuals. I was wondering if this a common problem. I hope it's just a vacuum problem.
Old Mar 13, 2008 | 04:11 PM
pablocruise's Avatar
pablocruise
Check under the passenger side fuel-rail cover.
There is a vacuum check valve there that deteriorates and leaks the vacuum.
Check the lines also for brittleness/cracks.
Old Mar 13, 2008 | 07:13 PM
BobRR3's Avatar
BobRR3
If your cruise control works, It's not the check valve. The most common problem for what you are describing is usually the vacuum module. The connector to the module needs to be replaced or eliminated.
Do a search. you will find the procedure for removing the Vacuum control module and the repair. I did mine with the help of the forum. It's not huge project.
Good luck
To Hvac problems
