Gas Prices!!
Your statement about spark advance is ludicrous, regardless of what gasoline you use. The declaration, "The more spark you can run, the more power you can make." is proof positive of a lack of understanding of engines. And to cap it off with "It's pretty simple really." Is the icing on the cake of ignorance.
Everywhere else, people run as much a advance as possible until 1) the car doesn't make any more power, or 2) it knocks.
Here is another example where I have responded to the OP, and you had to chime in and reply directly to me because you are uncomfortable that someone else might know what he is talking about. You go ahead and continue to argue with Onyx about how running less octane than what GM recommended is fine.
Hey, whats the FSM say?
-- Joe
I am not arguing. I made statements, and you said I was wrong. Tell me, what statement(s) of mine are you saying is wrong? Quote it, please. The same for ALL those who have "challenged on this thread by folks who OWN and DRIVE LT1's". Tell me, what is it I said that has you so up in arms?.
RACE ON!!!
Here is some information for those who understand, unlike Jim here who thinks "the more spark advance you can run, won't make more power". Because Jim here has a slow turd that runs on 85 octane.
Here is one of the many tables the ECM uses to deal with low octane. After running for a while, the premium fuel bit will be set or unset in mosts masks. (this logic is MUCH more advanced in the LT1 bins, although my example is $8D).
http://members.cisdi.com/~anesthes/low-octane.jpg
And here is an example of what happens when your motor is tuned to a specific octane (the example here is '93) and you try to get away with '89 octane)
http://members.cisdi.com/~anesthes/low-octane-log.jpg
Notice how much spark retard ? The total commanded advance would have been about 29 degrees, but at some points it takes away as much as 6-7 degrees of advance total, leaving you (me) with around 22 degrees total advance. Some people say for every degree of advance you can get away with, you'll unleash about 10hp. If thats true (which those of you who have dyno tuned their built motors will know - again not a stock '84 running 85 octane) we're talking a 60-70hp hit.
-- Joe
-- Joe
To the OP: If the manual says to run 91 octane, run 91 octane. Despite what anyone on the internet will say, the designers of the engine know more than they do. So they probably have a damned good reason for saying to run 91 octane. If you want to cut fuel costs, drive a bit more conservatively. Don't give me that "I already do" BS, I own a Vette too, so I know you get onto it.
