searching for idle
Old Mar 13, 2008 | 10:17 PM
blue 85's Avatar
blue 85
Default searching for idle
When my 1985 goes into closed loop it won't idle. The idle will surge up to 800 or 900 rpm then drop off almost to stall at 300 or 400 rpm. happens alot in stop and go traffic. any suggestions???
Old Mar 13, 2008 | 11:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would start with re-setting min idle and TPS. Did this come out of nowhere ??
Old Mar 14, 2008 | 09:17 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Vacume leak
Old Mar 14, 2008 | 02:41 PM
blue 85's Avatar
blue 85
have done that .54 volts and don't hear any leaks???
Old Mar 15, 2008 | 06:54 AM
RRT vette's Avatar
RRT vette
Supply some more info for us. The two suggestions are the usual for unstable idle.
Old Mar 15, 2008 | 03:04 PM
PurtyLilC4's Avatar
PurtyLilC4
have you checked the IAC valve? could be a sign thats its beginning to wear out or build up dirt, debris, etc.
Old Mar 17, 2008 | 08:45 PM
blue 85's Avatar
blue 85
Will be checking the IAC today..
info 383 stroker 282/272 cam tune port with world 2.02 heads,headers running 8 degrees timing with a standard trans.
Old Mar 17, 2008 | 11:08 PM
AGENT 86's Avatar
AGENT 86
Did this problem come out of nowhere, or is this a new combo ??
Old Mar 17, 2008 | 11:52 PM
kenmack's Avatar
kenmack
Default EGR exhaust gas recycle
Could be EGR valve in intake,(this valve controls idle)possibly has debris in it.
Expensive to replace, buy some GM intake cleaner (spray bomb)and follow instructions to the letter.
I just did this on my 4.3 vortec(same symptoms) and it has never run so good.Took about 30 minutes.
You've only got 10-12 bucks to lose and if it doesn't solve it the improved mileage is payback aftera coupla tanks.
Old Mar 18, 2008 | 08:51 PM
blue 85's Avatar
blue 85
Did the IAC, and it is still doing it. will try the cleaner. And yes it came out of no where about two weeks ago..
Old Mar 18, 2008 | 09:23 PM
AGENT 86's Avatar
AGENT 86
Since your in Austin,Texas, I don't think it will be too hard to find a member here, that can put it on Datamaster or similar.
Sure makes it easier when you can see what the ECM is seeing/doing.
Old Mar 19, 2008 | 11:31 PM
blue 85's Avatar
blue 85
you would think...
Old Mar 23, 2008 | 05:02 PM
JeepCycle's Avatar
JeepCycle
Mine has had the same problem since I got it, I have tried everything(calibrating, cleaning, setting, resetting,and replacing the ignition and fuel system) but that....that was the suggestion given me by a(OMG) Ford Tech. I'll be all about it next weekend.
Old Mar 26, 2008 | 12:09 AM
kenmack's Avatar
kenmack
Default Test drive
P.S. After letting it sit for 15-20 min. Take it out on a quiet back road,for a ten min run.
I hit passing gear about 4 times in 10 min, drove home and it idled perfect every since. (2 mths now)
GOOD LUCK POST YOUR RESULTS!!!!!!!
To searching for idle
