A4 shift knob removal?
Old Mar 13, 2008 | 11:36 PM
383tpimachine's Avatar
383tpimachine
Default A4 shift **** removal?
Its one of the few things i lack in taking out the center console
I think it jsut screws on right? But couldnt get it to turn one bit
how you get the darn thing off?
Old Mar 14, 2008 | 12:21 AM
Frizlefrak's Avatar
Frizlefrak
Gently pry the button up and off, remove the Clip, off it comes.
Old Mar 14, 2008 | 08:56 AM
383tpimachine
should i pry from the back or front? and im guessing with a flat tip?
Old Mar 14, 2008 | 10:38 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Either way or both. Do it carefully.
Old Mar 14, 2008 | 02:56 PM
Frizlefrak's Avatar
Frizlefrak
You might want to use a popsickle stick as a fulcrum and use something plastic to pry with so you don't mar the shifter ****.
Old Mar 14, 2008 | 06:26 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
You will probably need to use snap ring pliers to get the clip out and to re-install it.
Old Mar 14, 2008 | 06:28 PM
383tpimachine
will use my homemade plastic flat tip screwdriver
works great to now scratch jacksquat
will try it out tonight
Old Mar 14, 2008 | 07:27 PM
QuikZilver's Avatar
QuikZilver
Yes, you will need snap ring pliers to get the snap ring off, once you have removed the button. Then, the handle just slides up and off. Won't take you long at all, if you have the right tools.
To A4 shift knob removal?
