Someone please check this for me
Old Mar 16, 2008 | 02:05 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default Someone please check this for me
I was poking around under the hood in the ASR area, actually started work on my cruise control and found a plug hanging. It is on the pigtail that has 3 plugs on it. 1 goes to the ASR 1 goes to the master cylinder and the other one in between those 2, which is a single wire plug brn/blk wire is just hanging. Could someone take a look at it on thier car and tell me where it goes?
Old Mar 16, 2008 | 02:21 PM
STL94LT1's Avatar
STL94LT1
It connects to the lower inboard part of the master cylinder.
Old Mar 16, 2008 | 07:27 PM
Redeasysport
Do you know what it is for? I found it now. Can you tell me wether the wire is up or down when it is plugged in. It looks like the plug could go on either way but I have it plugged in with the wire toward the top .
Old Mar 16, 2008 | 10:57 PM
STL94LT1's Avatar
STL94LT1
That's the brake fluid level sensor. The wire on mine is to the bottom of the connection. But, if you made the connection up, it should be OK.
To Someone please check this for me
