Dragging Brakes
Old Jun 19, 2008 | 05:08 PM
Leftoverture's Avatar
Leftoverture
I'm not sure I'm experiencing the exact same problem as my brakes were dragging only after it got wet, but I did find that the dust seal was off the slide pins on one rear caliper and the pins were very sticky. I cleaned the pins, relubed them, and made sure the dust seals were back in place. Works good now. I do know that the slide pins have to move freely or the calipers will not work correctly.
Old Jul 20, 2008 | 07:49 PM
EGT1's Avatar
EGT1
Default Brakes Fixed!
I replaced the master cylinder, flushed the entire system and put DOT 4 fluid in and the problem is solved!!! THANK YOU ALL for your help!
