hard starting
Old Dec 8, 2001 | 08:33 PM
dt35th's Avatar
dt35th
Default hard starting
bought 1988 in june, car has started with no problem. now that it finally cooled off here in the northeast car does not start right away. have to keep cranking and playing ( no pun intended) with the gas pedal to start. Is there a cold start injecter on this car.HELP Thanks
Old Dec 8, 2001 | 11:38 PM
jfb's Avatar
jfb
Default Re: hard starting (dt35th)
Yes, it is on the rear left side of the FI manifold. Try unplugging it and plugging it back in. It takes some force to do this. See if there are any codes stored because the cold start injector is triggered by the temp sensor at the front of the engine and if this is defective, the cold start inj won't be activated causing hard cold starts.
