Small cap distributor options
Old Mar 17, 2008 | 05:39 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Small cap distributor options
What small cap distributors will work with an '89.... (The only one I've seen mentioned so far is > $300).
gp
Old Mar 17, 2008 | 05:47 PM
JackDidley's Avatar
JackDidley
Distributors from Most F bodies and trucks of that era should work. Did you try the local parts stores ?
Old Mar 17, 2008 | 08:26 PM
GREGGPENN's Avatar
GREGGPENN
No. I don't think the avg retail auto counter personnel would know that. So which F bodies/trucks use a small dist with the same plug config as our vettes? I don't know....
I saw a thread on an MSD dist that includes a reference to an expert who knows how to repin/remap distributors. I also see where small caps run $140 up.... I'm guessing some of the lower priced distribs will work, but a few threads that cover the subject seem to talk about the MSD 8366.
Old Mar 17, 2008 | 09:04 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Try posting a "Want to Buy" in the for sale section. Also, there are a couple of used 8366's for sale over in Thridgen.org.
Old Mar 17, 2008 | 09:06 PM
JackDidley's Avatar
JackDidley
Someone sells the adaptor harness to switch to the small distributor, I cant remember who. Maybe Jims Performance ? Seems like it was $20. My 89 Camaro has a small distributor that I am sure would work with the adaptor.
Old Mar 17, 2008 | 09:46 PM
anesthes's Avatar
anesthes
You need a small cap dizzy + coil from a 88+ fbody, or 87+ full size pickup, or TBI caprice, etc, etc. Might as well grab a section of harness and just splice the wires, unless you can find the adapter somewhere. You'll also need to splice or adapt the power + tach wires for the coil.
I imagine you want the small cap dizzy to decrease the amount of voltage required to jump the gap with more advance? I've run both setups over the years.
-- Joe
Old Mar 18, 2008 | 03:56 AM
rodj's Avatar
rodj
-- Joe
www.eficonnection.com or Jims performance
do a nice custom adapter harness.
Old Mar 18, 2008 | 08:34 AM
Z01#316's Avatar
Z01#316
gp
I just finished gathering up a small cap conversion for my soon to be done FIRST install. I bought a new small cap distibutor and associated harnesses from Tpi parts on Ebay, for about $250.00 all together. Distributor by itself was $170.00. I don't know if u can get it cheaper throgh a local parts house or not. I couldn't find a better deal. Hope this helps, Tom
Old Mar 18, 2008 | 09:38 AM
anesthes's Avatar
anesthes
I think reman units are $99 at autozone. I have a few in my shop with broken cap screws. They all oxidize and the screw breaks off into the bottom plate when you try to remove the cap.
-- Joe
Old Mar 18, 2008 | 11:25 AM
opel's Avatar
opel
-- Joe
Will the MSD 8366 work on an 85 Vette?
Dave
Old Mar 18, 2008 | 01:02 PM
Z01#316's Avatar
Z01#316
-- Joe
Well, that's good to know (in hindsight) . Mine is a new GM unit. Any idea what cause the oxidation and a way to prevent it?
Old Mar 18, 2008 | 01:27 PM
mk842766's Avatar
mk842766
gp
got mine from White Performance on ebay...quality unit for less than $100....works great...
Cheers,
Michael
Old Mar 18, 2008 | 04:54 PM
anesthes's Avatar
anesthes
Dave
With the appropriate wiring changes, sure. 8366 is a small cap, direct replacement for small cap HEI applications.
-- Joe
Old Mar 18, 2008 | 04:56 PM
anesthes's Avatar
anesthes
No idea. I've seen it on trucks, fbody's, some older police cars. The screws are a way to small diameter so they snap the second you try and loosen the cap.
-- Joe
Old Mar 18, 2008 | 06:07 PM
hexane's Avatar
hexane
I have a small cap HEI for sale. To convert to a small HEI, you need the connectors and you will need to splice the 4 prong harness with one from an fbody or truck. Also you will need an external coil.
To Small cap distributor options
