The right combo
Old Dec 9, 2001 | 12:07 PM
lowace's Avatar
lowace
8th Gear
Default The right combo
Ok I decided to go with the trick flow G2 heads on my 86 coupe. The question I have, what cam I should use to get the best performance out of these heads. Im not changing the stall converter or gearing.So would it be worth changing the cam or should I stay stock ? :chevy
Old Dec 9, 2001 | 01:14 PM
mean8t's Avatar
mean8t
Default Re: The right combo (lowace)
What mods do you have/going to make on the TPI?
Old Dec 9, 2001 | 01:35 PM
lowace's Avatar
lowace
8th Gear
Default Re: The right combo (mean8t)
right now none
Old Dec 9, 2001 | 03:53 PM
mean8t's Avatar
mean8t
If your not planning on doing any mods ever that would chose one cam, and if you are going to do some mods, TB, runners, and intake base, and headers. Then I would say a different cam. I would suggest ZZ-9, or XE268H-14
Old Dec 9, 2001 | 07:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't remember if '86 has a roller cam or not. So you might have to do lifters too.
If you plan on other mods I too would suggest the cam (and lifters if needed); if not just do the other mods. I haven't touched heads or cam yet and picked up about 60hp at the crank from the other stuff.
I have some mods data you may find useful; you've got mail.
Old Dec 10, 2001 | 12:23 AM
mean8t's Avatar
mean8t
Default Re: The right combo (65Z01)
On the other hand TPIS picked up something like 50 or 60 hp on just their super L98 cam alone.
Old Dec 10, 2001 | 01:23 AM
65Z01's Avatar
65Z01
My reported test data changing to the Super Profile cam (installed at 106 deg ATDC) in the '90 L98 shows a gain of about 2.5mph in trap speed or about 25hp at the crank. That was before they did other major mods but after the Fast Pack, etc. mods.
[Modified by 65Z01, 11:25 PM 12/9/2001]
Old Dec 10, 2001 | 03:28 PM
mean8t's Avatar
mean8t
65Z01 THanks for squareing me away, I have never tried the Super Profile cam so I had no idea.
To The right combo
By Michael S. Palmer | 2026-06-03 09:39:05
