1986 auto trans slipping - help!
Old Mar 20, 2008 | 07:07 PM
snowwhite's Avatar
snowwhite
7th Gear
Default 1986 auto trans slipping - help!
I went for a drive today and when I mashed the pedal to get into passing gear, the tranny didn't engage. I then had to limp home in 2. The only engagement is in 1 and 2, not D or OD. This is the first time it has done this since I've had it. The previous owner had a leak fixed on one of the seals. The C4 has 70,000 miles on it. Where do I go from here?
Any info or help will be greatly appreciated.
Old Mar 20, 2008 | 08:37 PM
Pete K's Avatar
Pete K
If the fluid level is full, and you lost 3rd gear, the 3-4 pack is toast.
The solution is:
Remove trans and overhaul
Remanufacture existing torque converter, or replace it with a remanufactured unit
flush cooler lines
