Fuel pump issues?
Old Mar 20, 2008 | 10:50 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Fuel pump issues?
89 vert. When I turn on the key, no pump sound. Cranks about 10 seconds before catching. Once started, runs perfect. Any issues here? Shouldnt I here pump in the on position before cranking? Thanks all for input.
Old Mar 20, 2008 | 11:29 PM
StephensblackL98's Avatar
StephensblackL98
Perhaps I'm just hard of hearing, but I've owned four C4's, and I've not heard the fuel pump, yet.
If it takes 10 seconds for the motor to fire, something ain't right. Anything from coil to plugs to injectors, to about a dozen other things. I'm sorry, I'm not helping a lot. I've had L98's like yours, and LT1's. Never took 10 seconds to start. Good luck finding your problem.
However, if you find you have to replace the fuel pump, it's a breeze. I have just completed the job, and it's the easiest thing you'll do on your car.
Old Mar 20, 2008 | 11:31 PM
rodj's Avatar
rodj
Fuel pump relay /connector plug or wiring to it / no signal from computer.
"Cranks about 10 seconds before catching."
You are starting on the fuel pump oil pressure switch which runs pump after oil pressure builds.
Check pump relay first.
Can swap with the fan relay to confim operation
Old Mar 21, 2008 | 11:11 PM
CorvetteMike2024
Corvette Enthusiast
Default relay
Which relay is for fuel pump? I have one by wiper motor and one on fender well. Thanks for help. Are these it? If not where?
Old Mar 22, 2008 | 12:23 AM
RRT vette's Avatar
RRT vette
The fuel pump relay is located on the firewall next to the windshield wiper motor. You can get a fused jumper wire and stick one end into the first terminal on the fuel pump relay connector and the other end into the last terminal of the fuel pump relay connector. This will bypass the relay and the fuel pump should run (key off), if this is your problem.
Old Mar 22, 2008 | 01:16 PM
CorvetteMike2024
Corvette Enthusiast
Default new relay
I put in the new relay, still no pump sound. Any more suggestions? Thanks again
Old Mar 22, 2008 | 02:26 PM
CFI-EFI's Avatar
CFI-EFI
Throw more money at it.
RACE ON!!!
Old Mar 22, 2008 | 02:49 PM
rick lambert's Avatar
rick lambert
I'd check the wiring going into the fuel pump relay, several of us have found the insulation on these wires shrink back and expose bares wires. Mine had shrunk 3/4 of an inch and were in contact with one another. If you run a wire from the positive side of the battery to terminal G on the ALDL, the only pin on the lower side your fuel pump should come on...if it does you have a wiring circuit problem. And you might want to just swap the relay with the one on the wheel well...just to make sure even the new one is good. The ALDL is just above your knee on the drivers side.
To Fuel pump issues?
