Discount GM Parts
Old Apr 6, 2008 | 10:10 AM
WVZR-1's Avatar
WVZR-1
I believe though that after you factor in their 20% shipping and handling plus a couple dollars that they seem to convenienly add the final will likely be higher. Try to return a wrong part! I would avoid them.
I'd be inclined to maybe pay a bit more at the local dealer and have a "hand to shake" after he's sold you the right part or who's standing right there "toe to toe" if you've a problem. Shipping has become a serious pricing issue recently, a local purchase eliminates at least that!
Old Apr 6, 2008 | 01:15 PM
hgh pwr's Avatar
hgh pwr
I've had problems with gmpartsdirect and would not recomend using them.I have had good luck with jim pace pontiac and they did match the amounts of the less expensive warehouse company's.
Old Apr 6, 2008 | 03:58 PM
frankzappa's Avatar
frankzappa
Cruising
Default Parts direct
Just purchased a GM slave cylinder and master. Installed well. No bleeding necessary other then drip feed method. Have rock hard clutch with No play. Thumbs up
