Vats key
Old Mar 24, 2008 | 11:17 AM
donhouk's Avatar
donhouk
Default Vats key
HI, Just measured resistence on 2 ignition keys for a 96 CE. One was in the 3 range - the other in the 7 range. I must be making a mistake. This isn't possible, is it? Regards, Don
Old Mar 24, 2008 | 11:57 AM
rick lambert's Avatar
rick lambert
Don, I think it is possible. If memory serves correct there are a few different ones. Someone here posted them quite awhile ago. What's important is you measure the resistance of your original and then match it.
Old Mar 24, 2008 | 11:58 AM
StealthLT4's Avatar
StealthLT4
Do both of them work? Are you sure you were making correct contact with the leads on either side? Did you clean them first?
Not too long ago, a member posted the full list of resistance values and the corresponding VATS code. I'm not sure; maybe 3-7 ohms are in one range; it's entirely possible, since you can get resistors up to 10 k-ohms commonly.
Old Mar 24, 2008 | 12:06 PM
donhouk's Avatar
donhouk
Default vats key
Thanks guys, I think I'll clean the contacts with alcohol - try again - and take the other key out and try it. (sometimes I miss the big picture). Regards, Don
Old Mar 24, 2008 | 12:19 PM
pcolt94's Avatar
pcolt94
I think there are 12 different VAT key resistance values if memory serves me correct. And I can tell you for sure that there are none down in the 5 ohm range. A value of 3000 or 5000 might be in the ranges used for the keys. From memory again, I think I have key 6 and mine measures 1462 ohms (1.462K).
Old Mar 24, 2008 | 12:22 PM
donhouk's Avatar
donhouk
Default Vats Key
The mystery seems to be solved. The other key in question wouldn't turn on the ignition. But the THIRD vats key in my hide a key did. Therefore, when I bought my car three years ago, he must have included his wife's car keys. (not a bad idea). THANKS! Don
Old Mar 24, 2008 | 12:25 PM
Red Guts's Avatar
Red Guts
# Value Range
1 .402 .386-.438
2 .523 .502-.564
3 .681 .650-.728
4 .887 .850-.942
5 1.130 1.085-1.195
6 1.470 1.411-1.549
7 1.870 1.795-1.965
8 2.370 2.275-2.485
9 3.010 2.890-3.150
10 3.740 3.590-3.910
11 4.750 4.560-4.960
12 6.040 5.798-6.302
13 7.500 7.200-7.820
14 9.530 9.149-9.931
15 11.800 11.320-12.290
Old Mar 24, 2008 | 12:38 PM
pcolt94's Avatar
pcolt94
Originally Posted by Red Guts
# Value Range
1 .402 .386-.438
2 .523 .502-.564
3 .681 .650-.728
4 .887 .850-.942
5 1.130 1.085-1.195
6 1.470 1.411-1.549
7 1.870 1.795-1.965
8 2.370 2.275-2.485
9 3.010 2.890-3.150
Nice job! I beleive these values to be in the K range or times 1000. So all understands.
To Vats key
