Induction
Old Mar 24, 2008 | 07:46 PM
383tpimachine's Avatar
383tpimachine
Default Induction
Ive seen on here a few times where people cut holes under their air filter for more fresh air
my question is does this really help alot? and can i see some pictures if it lives up to the hype
Old Mar 24, 2008 | 08:03 PM
MK 82's Avatar
MK 82
No!
Old Mar 24, 2008 | 11:21 PM
Eddie & the Cruisers's Avatar
Originally Posted by MK 82
No!
Is that a NO to one or the other or both questions?
By drawing air from under the radiator shroud, you get cooler air that is denser than the air from the engine compartment and it does work.
Yes, the original location of the air filter intake is supposed to be sealed from the engine compartment, but most are not sealed very well and do draw warm to hot air into the system.
Denser the air, the better the air/fuel ratio, and better performance.
Last edited by Eddie & the Cruisers; Mar 25, 2008 at 01:09 AM. Reason: Spelling and grammar
Old Mar 25, 2008 | 12:28 AM
383tpimachine
ummm so thats a random unknown no and a yes it will help
so holes are one up right now
Old Mar 25, 2008 | 01:11 AM
YES!
Go ahead and cut holes.
Old Mar 25, 2008 | 09:05 AM
383tpimachine
ok holes it is
Old Mar 25, 2008 | 10:17 AM
rickneworleansla's Avatar
rickneworleansla
Originally Posted by Eddie & the Cruisers
YES!
Are yout telling him to cut holes in the bottom of his filter housing?
Old Mar 25, 2008 | 11:01 AM
Aardwolf's Avatar
Aardwolf
Holes in the radiator shroud around the filter is what this sounds like. That would steal air from going through the radiator. If you cut it already, cover the holes up and check for gains or losses, then uncover them and check again. Tell us how much difference there is. I will bet there is no gain.
Old Mar 25, 2008 | 11:09 AM
Mojave's Avatar
Mojave
How does the temp of the air affect the air/fuel ratio(afr)? There is a mass air flow meter and a temp sensor. The afr should not change as the air temp changes, as the computer should add fuel if the intake charge is cooler to keep the afr in the right spot.
Colder air makes more power because you can add more fuel.
Old Mar 25, 2008 | 12:44 PM
383tpimachine
Havent cut holes and im refering to right below the air filter housing cutting a air duct hole
might or might not do it
depends how willing i am when the time comes
To Induction
