IRS weight ???
Old Mar 31, 2008 | 08:57 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Originally Posted by red L98
My rear-end has gun drilled axles, aluminum spool and yoke, pro gear and mostly chrome molly. also the fact that its narrowed makes everything like the axles and housing lighter. I was able to pick my housing right off the ground with no problem what so ever. Ill have the for sure weight saving for you guys this weekend …. Thanks
So, did you get it weighed?
Charles
Old Mar 31, 2008 | 09:19 PM
red L98's Avatar
red L98
no sorry guys, but ill have the weight of both my rearend and another 12 bolt that my friend has, its the same length axle to axle of a stock dana 44. ill have it for you guys in few days .
Old Apr 7, 2008 | 09:54 AM
cbernhardt's Avatar
cbernhardt
I attended the Charlotte Auto Fair this weekend and talked to a custom solid axle builder. He said his 12 bolt rear (cast housing), hub to hub with Wilwood brakes would weigh about 250#, that does not include springs, shocks, linkage. 8" with fabricated steel housing would be about 20# lighter. Would still be curious as what your's (red L98) weighs.
Charles
Old Apr 7, 2008 | 10:06 AM
anesthes's Avatar
anesthes
Originally Posted by hooblyboobly
Removing the IRS and replacing it with a straight axle could contribute to some weight savings. I hope I can get it down to less than 2700 lbs one day.
It's kinda funny. You got some guys who spend tons of money trying to make the car handle and corner better.
Other guys swap in solid axles, manual racks, etc.
I like the idea of a fast C4, but if you want race car I think you should build a Vega. Not to say there isn't a lot of fast (10 second) C4's in full race trim, but is it still a C4?
-- Joe
