Idle problems after rebuild
Old Mar 25, 2008 | 08:01 PM
Outlander99's Avatar
Outlander99
Default Idle problems after rebuild
Hi Guys, my 1990 Auto has just been rebuilt and having trouble with idle, The specs are based on a ligenfelter grind with the following details: duration@50, 243 Intake, 251 exhaust, adv duration 294 intake, 302 exhaust, lift @ valve .560 intake, .565 exhaust, 1.5 rocker ratio, 1.75 spring height, 100lb springs, closet seat, lobe sep 110. all cylinders are .30 over.
PCM for less has done several burns for us but still no luck. It appaers that the vaccum may be the issue and causing problems with the map sensor. This motor is raunchy and we just cannot get the thing to idle at all. We are at the point of pulling the cam and going to something a little milder. any thoughts or suggestions would be a great help.
Old Mar 25, 2008 | 11:20 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Reset the minimum air speed,IAC,and TPS..you may have to find a sweet spot to get it to run right.The factory settings may not be up to par.
For exmaple,if the factory is say 450 or 550 rpms at the TB,you may need to set it a little higher.
Old Mar 25, 2008 | 11:44 PM
_twisted_'s Avatar
_twisted_
If the only problem you have is with idle - set the min idle about 25-50 rpm below the target idle for the ecm. you might even get to the point of disconnecting the iac altogether.
My cam isnt that nasty and mine idles at 1275 in park and neutral, 850 in gear
Old Mar 27, 2008 | 07:58 PM
Outlander99
Well Neither seem to be working, looks like the cam is just too agressive, Need some help or suggestions!
To Idle problems after rebuild
