Wheel Adapter/Spacer for 1986 Corvette
I had someone give me 4 chrome 5 Star 1999 Trans Am factory rims. I believe they are 56mm offset????. I would like to put them on my 86. Do I need spacer/adapters to run these wheels. If so what size do I need? I believe the 86 is 36mm offset. Any help would greatly be appreciated.
Thanks.
Thanks.
You will need adapters that are 3/4" thick to get the F-body wheels to sit properly in the wheelwell. Without them, the wheels will sit too far inboard. The 18mm difference in offset is the 3/4".
The adapters bolt to the hub using extra lugnuts. The adpaters have their own studs for attaching the wheel.
Some adapters come with an "acorn-style nut that sticks out past the face of the adapter flange. The wheels should have a recess on their mounting flange so that the nut will sit in the recess and allow the flanges to fit flush.
Good adapters can be pricey!
Thanks.
Thanks.
It's not that noticeable. Here is a pic of 90 wheels(similar offset) on my 86. It does look better with adapters, though.
Here is a pic with adapters on front. The previous set of 90's were replaced with this set from a 90 ZR1. The rears didn't require any adapters(wider and different offset).
i have just gotten a 1986 vette and i got a set of 1991 vette 17 " wheels.What size spacer do i need and where is the best place to get them at a resonable price.I have seen spacers on ebay for around 40.00 a set of 2 but don't know if they are any good. You can email me at wils9361@bellsouth.net or on here fo a reply.im ready to buy now.
