93 Interior light problems
Old Mar 28, 2008 | 04:55 PM
jd48's Avatar
jd48
Default 93 Interior light problems
Problem started after door panel and console lid where relaced.
Probely has nothing to do with it. BUT....
Now I have no interior lights when door is opened or by switch.and the relay is buzzing away even with no key,never stops buzzing.
Cargo lights still work. Have a sys error meesage with H25 .
Any advice??
Old Mar 28, 2008 | 06:32 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The RH CTSY 5 amp fuse is most likely blown.
It's located in the fuse panel passenger side end of dash.
Old Mar 28, 2008 | 07:37 PM
jd48's Avatar
jd48
Checked`all that stuff. even have power at lights .seems to be a ground problem I hope
Still looking
Old Mar 29, 2008 | 02:29 AM
sweetbaboon's Avatar
sweetbaboon
Had the same problem and that was the fix.
Old Mar 29, 2008 | 10:52 AM
jd48's Avatar
jd48
Fuses are fine.
Old Apr 12, 2008 | 06:31 PM
1993Ruby's Avatar
1993Ruby
6th Gear
Default Did you solve the problem yet?
I am having a similar problem...my door panel is loose and something seems to be wrong with the interior lights. I checked the fuses, but everything looks OK. Whatever it is seems to have drained the battery.
I am curious if you got the problem solved?
Old Apr 12, 2008 | 06:53 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I'm curious about this one.
Old Apr 20, 2008 | 04:19 PM
MY93TOY's Avatar
MY93TOY
I had my doors open today for a while and I know its normal for the light to turn off but now they wont come back on. I can turn them on manually but when I open the door they wont come on. Anyone know about this ? Dose it have to reset or something?
Old Jun 8, 2023 | 01:48 PM
Max_93'Vette's Avatar
Max_93'Vette
3rd Gear
Any advice??
going through the same stuff right now. got the buzzing after getting my driver door replaced. my footwell and door lights and mirror lights don’t come on. i’ve got the h25 code as well. not sure what’s goin on.
To 93 Interior light problems
