OK Guys, need some serious help!!
Old Apr 14, 2008 | 01:08 PM
  #321
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by Paul Ruggeri
Before you pull the pan or the heads or anything else, get a boroscope, that may not be the correct spelling, and look inside the cylinders. Its like those things plumbers use to check inside your pipes. You can stick it into the spark plug holes and see if anything is in there.
Now that you have oil to the rockers, I think we can rule that out as the problem. I'd lean towards the something fell in the engine theory at this point. If you can see it with the boroscope you might get real lucky and be able to fish it out witout a major teardown.
Paul
I am trying to find a rental place right now.
Old Apr 14, 2008 | 05:13 PM
  #322
jsup's Avatar
jsup
Guys, I've been listening to this. I think I'm screwed. Sounds like a bearing is spun/rod knock. It is coming from the lower end. I played a little hookey from work today and fked with the car. I'm resigned to the fact I probably need a rebuild.
I'm kicking myself wondering if it is coincidence or if I did somehting stupid. As I thought about it the oil pressure fluctuated for a couple seconds down to zero and back up. I chalked it up to the system re priming itself. It was brief and inconsistent.
I am kicking myself pretty hard right now.
I went to a local, respected builder and we're looking at more than $2K, but less than $3K. Seems stroking it would be more $$$
The other option is Scoggin Dickey has a 383 bottom end I can just drop in.
http://www.sdparts.com/product/12499...eAssembly.aspx
Old Apr 14, 2008 | 05:15 PM
  #323
anesthes's Avatar
anesthes
That stuff only makes noise under LOAD. Wouldn't do it cranking.
Unless the bearing FELL OUT, which is almost impossible. It would have exploded.
-- Joe
Old Apr 14, 2008 | 05:42 PM
  #324
jsup's Avatar
jsup
-- Joe
Oh, it's definitely mechanical. If you put your hand on top of the super ram you can feel it through the block. It's hard.
Old Apr 14, 2008 | 06:23 PM
  #325
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Have you even inspected the flex plate yet? It's 4 small bolts for the cover. No matter how time constrained you are, I'd do that before laying down $2k+ on a motor.
Old Apr 14, 2008 | 06:27 PM
  #326
jsup's Avatar
jsup
Tomorrow, it's going to the lift at my friend who is a mechanic. He'll check it out. See the posts above.
After spending more time with it today, and getting another set of ears on it, I am not optimistic.
Old Apr 14, 2008 | 09:49 PM
  #327
95BLKVette's Avatar
95BLKVette
Damned, what a story, was hoping for a happy ending though
Just couldn't stop reading all the posts!
Good luck, and please let us know what it is
Dumb question, but why didn't you loosen all the lifter adjusting nuts to totally eliminate valve train noise.....judt think, if that makes it go away, then you know it's probably an overtight or stuck lifter.
A totally toasted rod bearing could cause enough pressure leakage into the pan to prevent lifter pump up....
Yup, lossen the lifters, spin one more time, if still noisy definately pull the pan...
Again, good luck, I've been there
Old Apr 14, 2008 | 09:57 PM
  #328
Pete K's Avatar
Pete K
Keep us posted
Old Apr 14, 2008 | 10:04 PM
  #329
jsup's Avatar
jsup
To me right now the issue is time. As much as I enjoy diong this as a hobby, yes I said enjoy, I am going to pay someone to drop the pan, check the flexplate, and narrow down exactly what it is.
I am expecting a trashed bearing.
Anyone in northern NJ wanna come pull a motor out?
Old Apr 14, 2008 | 10:54 PM
  #330
jsup's Avatar
jsup
Ya know, that would explain everything. Good call. We'll see tomorrow.
Old Apr 14, 2008 | 10:58 PM
  #331
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
If the problem was only one bearing,why would it cost nearly 2K to repair?
I know thats guessimation but until you know for sure,theres not a real price you can attach.Hope you find out what it is soon.
Old Apr 14, 2008 | 11:02 PM
  #332
jsup's Avatar
jsup
Because I'd have to do the entire bottom end. I know it can be done in the car, however, until I isolate the specific problem, I can't know why this is happening. The root cause of the problem, and if it can happen again. The guys who work on my car won't do an in car replacement of one bearing.
If I'm going to take it that far, I'm going to get it done completely, and done right.
I will re use the rods based on how they measure, maybe even the piston based on what I find.
I'm getting ahead of myself....we'll see what it is tomorrow. I hope.
Old Apr 14, 2008 | 11:28 PM
  #333
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Sorry to hear of all this John. It would be nice to understand what happened. I know if it were me, I would be pulling my hair out. Maybe you'll still get some good news...
Randy
Old Apr 15, 2008 | 01:07 AM
  #334
cv67's Avatar
cv67
St. Jude Donor '05
It would suck if you put a bottom end in it and had a flexplate noise.
Pul that cover off before you do much else.
Old Apr 15, 2008 | 05:51 AM
  #335
toptechx6's Avatar
toptechx6
My money is still on something dropped down the intake or injector ports.
Old Apr 15, 2008 | 06:16 AM
  #336
Weav's Vet's Avatar
Weav's Vet
Back in '74 I had a GMC pickup. 350 in it. I tightened up a belt to tight and the front main spun. Knocked like crazy under a load and you could hear it a idle. OP was very low. The truck only had like 30K on it. I dropped the pan and used plastigauge to check the clearance (that stuff still around?). Got a oversized bearing stuck it in and put over 145K on the truck (speedometer cable broke around then) before getting rid of it. It hauled several boats during it's life.
Old Apr 15, 2008 | 07:25 AM
  #337
JLeatherman's Avatar
JLeatherman
If it's just one bearing you don't need a whole bottom end. You don't even need to remove the engine from the car. Put a new bearing in it and run it.
To OK Guys, need some serious help!!
Old Apr 15, 2008 | 12:23 PM
  #338
rick lambert's Avatar
rick lambert
Quit kicking yourself......I think you're doing the right thing now, and he can inspect the flex plate while it's up too.
Old Apr 15, 2008 | 03:38 PM
  #339
jsup's Avatar
jsup
Thanks guys.
The car is now on the lift and in the hands of a very competent mechanic, and we are not optimistic.
He's pulling the pan to see what is up.
Perhaps Pics later.....
Old Apr 15, 2008 | 04:31 PM
  #340
jsup's Avatar
jsup
Just got back from the shop. They let me work on the car with them, they're good guys.
Id does not appear any of the rods are loose, whew...but he's dropping the flex plate as we speak.
No news yet.
It sucks that I don't have the time to do this myself, but better to have a car that I can drive than is sitting in the dam garage.
I should know by tomorrow.
