OK Guys, need some serious help!!
Old Apr 2, 2008 | 09:08 PM
  #101
CFI-EFI's Avatar
CFI-EFI
Originally Posted by jsup
I'm gonna try taking off the top of the SR plenum and sticking a magnet down the runner holes to see if anything comes out......before I take it all apart.
That would be a waste of time, unless you will be in the process of tearing it down. If something were on top of a valve, it would either drop into the cylinder when the valve opened, or it would jam between the valve and the seat causing a massive miss. If there is something in the cylinder, you won't reach it with a magnet. If something you dropped didn't get into a cylinder, it wouldn't be causing that noise. Simple logic.
I have heard a similar noise before, but I can't put my finger on it. Is there a spark plug out or loose? Is the header leaking where you have removed the A/C compressor mounting brace, or anywhere else?
RACE ON!!!
Old Apr 2, 2008 | 09:12 PM
  #102
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
RACE ON!!!
Thanks man. I will check that on Sat., I'm slammed the next couple days. Keep listening to it, maybe it will jar your memory.
Anything but a nut or something down the hole!!!! Thanks for the encouragement.
I was thinking, and remember, I'm not in a clear state of mind, that the nuts I used to secure the SR were too big to drop past the valve and got caught on the top of the valve and may be getting smacked around the top of the valve, in the head.
Old Apr 2, 2008 | 09:19 PM
  #103
cv67's Avatar
cv67
St. Jude Donor '05
Its not something in the cylinder, has a mechanical sound as if its keeping rythym. Valvetrain somewhere. Let it run longer and see if oil comes out...Do it anyway.
Edit: Kind of like a lifter that isnt pumping up.
Old Apr 2, 2008 | 09:22 PM
  #104
jsup's Avatar
jsup
The oil pumps up fine, I'm afraid to let it run up. Lifter, however, interesting call. That does sound somewhat reasonable...I put in new lifters to avoid such a problem..
Any way to test that?
Watch the rockers, they all move full throw.......if the lifter was bad, why would they move?
Old Apr 2, 2008 | 09:25 PM
  #105
anesthes's Avatar
anesthes
If it was a lifter, you'd have loose rockers..
-- Joe
Old Apr 2, 2008 | 09:27 PM
  #106
jsup's Avatar
jsup
-- Joe
Right, and they wouldn't rock....no loose rockers. I'd give my left nut for a loose rocker right now....
All my common sense is out the window right now....I'm just too dam close to it...I have to drive seven hours tomorrow, lots of time to think.
  #107
KEG64's Avatar
KEG64
The frequency of the noise appears to correspond with the movement of the rocker arms.
Old Apr 2, 2008 | 09:29 PM
  #108
cv67's Avatar
cv67
St. Jude Donor '05
Id bet the farm you either have a lifter issue or no oil pressure at all.
  #109
Aardwolf's Avatar
Aardwolf
That sounds mechanical, it also sounds like a lifter. I agree check the rockers. I had a flywheel bolt back out one time and that was much louder and less fast in speed.
  #110
jsup's Avatar
jsup
I have heard valve clatter before, this is MUCH MUCH louder.
Old Apr 2, 2008 | 09:30 PM
  #111
_twisted_'s Avatar
_twisted_
when you yanked the 22's did you check to see if all the pintle caps were accounted for? some are plastic some are not
  #112
jsup's Avatar
jsup
All rockers are tight.
Old Apr 2, 2008 | 09:32 PM
  #113
jsup's Avatar
jsup
If by pintle caps you mean the blue plastic things for shipping, then yes...if they are part of the injector, then no.
Old Apr 2, 2008 | 09:50 PM
  #114
Corvette Chris's Avatar
Corvette Chris
Something in the valvetrain isn't right. How long have you run the engine so far? Reason I ask, is in my book, there should still be some visible oil on the heads. Even if it has been a few days.
Old Apr 2, 2008 | 09:54 PM
  #115
jsup's Avatar
jsup
there is some oil in the heads, it's all pooled on the bottom.
The car sat for two weeks, then I started it and got this noise. I only started and ran it for short bursts like that after hearing the noise.
Old Apr 2, 2008 | 09:58 PM
  #116
Corvette Chris
And when you pulled the intake, to do the injectors, you left the heads alone, right?
  #117
_twisted_'s Avatar
_twisted_
it does sound dry - is your oil pressure good?
Is the distributor seated all the way?
To OK Guys, need some serious help!!
  #118
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Too fast and too high pitch to be a rod knock. Somthing is hitting something.
-- Joe
I agree. It doesn't sound like rod knock to me either.
Old Apr 2, 2008 | 09:59 PM
  #119
Corvette Chris
Thats what I thought too. I changed the oil in mine yesterday, and it sounded somewhat like that for the first few seconds until pressure built up.
Old Apr 2, 2008 | 10:04 PM
  #120
jsup's Avatar
jsup
Yes and yes. The OP goes up to about 80 and drops. Guage is working.
I'm using Mobil1 20-50. 15K oil.
Should I drain and re-fill?
This is really loud. You think I'm just not letting it run long enough? I'm afraid to do that.
