Removing cat problems
Old Mar 31, 2008 | 11:05 PM
88needspaint's Avatar
88needspaint
Default Removing cat problems
Anyone ever have a problem getting the main cat off? Does it have to be cut off? It sure as hell is on "tighter than a tick".
Old Mar 31, 2008 | 11:11 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I cut mine off...they seem to "weld" themselves on there over the years.
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I'm assuning you're talking about an 88. Generally you have to get the front red hot with a torch. The front clamp gets over tightened and embosses the front Y pipe. On rare occasions they will come off with a little (alot) of manipulation. The only other way I know is to cut aline on the front cat and then "manipulate" it off. I guess it depends on if you are planning to reuse it.
Old Mar 31, 2008 | 11:14 PM
88needspaint
I'm just trying to get the damn thing off, with limited tools. I'm not planning on re-using. Thanks for the tips and help!
Old Mar 31, 2008 | 11:19 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
One tool, saws all...
Old Apr 1, 2008 | 09:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Cut a slit on each side and use a screw driver or pry bar to open it up.
Old Apr 1, 2008 | 12:26 PM
88needspaint
Went to Wal-Mart and bought their little torch, heated for about 30 minutes and then cut a slit with a several screwdrivers. Pretty tough to get off without proper tools!
Old Apr 1, 2008 | 01:06 PM
Pelleplutt's Avatar
Pelleplutt
I use a dremel with a reinforced cutting wheel on it for this kind of job.
It it a very small machine to use but you can easy cut where there is very limited space.
I took away my cat when i was installing my headers and it was really bad to take away even with the front y off the car.
Pelle
-90 vert ZF6 trippleblack
To Removing cat problems
