wierd screw pattern anyone seen this?
Old Apr 1, 2008 | 09:51 PM
James Paradiso's Avatar
James Paradiso
Default wierd screw pattern anyone seen this?
I'm trying to replace my FPR and the screws that hold it on are a start patter, (common) but there is a small needle stud protruding from the center of the patter. I'v never seen this before nor a tool that is a star pattern with a hold in the center to accompadate this type screw.
Any help on getting off would be sweet, i tried to use a pair of pliers but the screws are pretty snug.
Old Apr 1, 2008 | 09:54 PM
Apathy93Z's Avatar
Apathy93Z
Sounds like a tamper-proof torx, you should be able to find them at autozone or any discount tool store. They look just like a torx bit but with a hole in the center.
Old Apr 1, 2008 | 09:56 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
Yup. Most of the name brand AFPRs come with a bit to remove that. Mine from TPIS did.
Old Apr 1, 2008 | 10:10 PM
Aardwolf's Avatar
Aardwolf
You can easily knock the pin out and save yourself buying the security torx bits. Use a small screw driver or your choice of tool to move the pin back and forth, it will break off easy. If you have to use a hammer with the driver on the pin.
Old Apr 1, 2008 | 10:48 PM
James Paradiso
cool, thanks guys, i could pickture the tool to remove it but have never seen one. I'll check my local checkers and napa and if they don't have one i'll try my luck at knocking the pin off. It's a pretty darn small torx screw so I don't think it will be easy to knock the pin off and not damage the torx threads at the same time.
Thanks for the ad!
Old Apr 1, 2008 | 11:12 PM
wingman4rent's Avatar
wingman4rent
Sears should have them also, I bought a whole set from them.
Old Apr 1, 2008 | 11:15 PM
Can86Z51's Avatar
Can86Z51
Thanks for the ad!
Yeah, a lot of electronics/small electronics use these small 'security'-type Torx fasteners, with the centre-pins. Small sets of suitable bits/screwdrivers are usually spold at outfits that carry small appliance-electronic-computer tools. Cheers!
Old Apr 1, 2008 | 11:16 PM
wro87's Avatar
wro87
Harbor freight has a 1/4" screwdriver in a plastic box that has a complete set of different bits. Som of the cheap tool sets that you find at the swap meets have the same. I picked up a set at Home Depot.
Good Luck wro87
Old Apr 2, 2008 | 08:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Buy the bit, trying to remove the pins may leave you with a bigger headache.
Also known as a security torx.
Old Apr 2, 2008 | 11:13 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
http://www.sears.com/shc/s/p_10153_1...per+proof+torx
Old Apr 2, 2008 | 11:24 AM
Elementaltoad's Avatar
Elementaltoad
soak them in WD40 or some other lubricant before removing them, i broke two security bits and striped the screws....AFPR never went in after that ordeal.
Old Apr 2, 2008 | 03:54 PM
87Beast's Avatar
87Beast
Look in the license plate cover area... I bought some of those security bolts for my plates - there was a package that came with 4 bolts plus a 6 or 7 piece set. It was at Napa or Schucks/Checkers.
To wierd screw pattern anyone seen this?
