cam
Old Dec 11, 2001 | 05:58 PM
GlockLT4's Avatar
GlockLT4
Default cam
Ok, since my thread about the cam got out of hand and wasn't talking about cams like I wanted to, we'll start over.
I was thinking something along the lines of the ZZ9 cam http://www.tpis.com/pg13-16.html
Or,
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
[Modified by Glock'94, 3:58 PM 12/11/2001]
Old Dec 11, 2001 | 06:22 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: cam (Glock'94)
I have the ZZ9 on my 355.. but have 1.6i/1.52e rockers
for your 383.. I would use one of these:
-CC305: Dur @.050 220/230 Lift w/1.5 rockers .510/.510 LSA 114
-LT4 Hot Cam: Dur @.050 218/228 Lift w/1.6 rockers .525/.525 LSA 114or 112 (can't remember)
Old Dec 11, 2001 | 06:39 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: cam (tntcorvette)
But his 383 will have stock heads and manifolds and such......
:confused:
Yeah but the cam will help a little with the stock heads..
better then swapping cams in a year or when he installs ported heads
I did the ZZ9 with stock heads cause I did not want to swap the cam when I swapped heads this year. I think he will be fine with either cam I suggested
Old Dec 11, 2001 | 07:02 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: cam (-=Jeff=-)
The CC305 cam will be pushing the limits of the springs you have to put on it with 1.6 rockers. Has .540 lift with 1.6's.
Old Dec 11, 2001 | 07:16 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
I did the ZZ9 with stock heads cause I did not want to swap the cam when I swapped heads this year. I think he will be fine with either cam I suggested>>
How well does that cam work with the stock heads?
Old Dec 11, 2001 | 07:20 PM
vader86's Avatar
vader86
Default Re: cam (FRISKY)
zz9
Old Dec 11, 2001 | 07:22 PM
-=Jeff=-'s Avatar
-=Jeff=-
OKay I guess, Obviously not at its full potential.. but drivability seemed fine
Old Dec 11, 2001 | 08:07 PM
GlockLT4's Avatar
GlockLT4
And the HOT cam... even though I have stock converter and gears right now, that too will change in the future.... probably 2800 when the tranny has to be rebuilt, and 3.73's when the rear end goes.
Old Dec 11, 2001 | 08:14 PM
Red Rocket's Avatar
Red Rocket
Had the ZZ9 cam with my 350 and stock heads with 1.6/1.5 and shortys. Car ran real good --12.8 at 110MPH. specs are 212/226 at 483/520 on the ZZ9.
Sorry Curtis, just sold my ZZ9.
To cam
