Inflatable Restraint Light.
Old Apr 3, 2008 | 04:43 PM
Allentown Ernie's Avatar
Allentown Ernie
Default Inflatable Restraint Light.
Gents, My inflatable restraint light and seat belt lite popped on and did not go off, on my 90 coupe so I unhooked the battery ground but the lites stayed on. I then downloaded the info that told me how to check for the codes and how to fix the problem with the sensor grounds. But first it said clear the codes as it might be a intermitent problem and it might be solved this way. I took my Vette to my buddy-mechanic and he checked it with his Auto-x-ray scanner. To my surprise he told me there were no codes stored, so there were none to clear. Now where do I start? Do I go to the sensors and clean the grounds or is there something else to do first? I hope there is some other fix as my car has ground effects to take off before I can get to the sensors. O.K. gentlemen scratch your heads and hopefully tell me where to start to fix this problem or just clean the sensors anyway. Thanks, Allentown Ernie.
Old Apr 3, 2008 | 04:45 PM
Allentown Ernie
Sorry about the double post, my mistake.
