dead 93 LT1 help please
Old Apr 3, 2008 | 06:28 PM
jimijam95's Avatar
jimijam95
Default dead 93 LT1 help please
I recently bought a 1993 LT1, only had 49k on her. Love the car, but on my way home the other day she died on me, after 4 tries she refired and I made it home... now she won't hit a lick... any ideas?
Old Apr 3, 2008 | 10:16 PM
jabez's Avatar
jabez
Need more info.
You didn't wash your engine recently did you?
Old Apr 4, 2008 | 05:46 AM
jimijam95's Avatar
jimijam95
No way, I know better than that. What is optispark?
Old Apr 4, 2008 | 06:54 AM
geogolf's Avatar
geogolf
Default car
hit a lick what does that mean, need to talk car terms does motor crank over and not start, or when you turn key it is dead ? optispark is what gm replaced distb. with starting in 92 it is on the frt of motor below water pump
Old Apr 5, 2008 | 01:34 AM
jabez's Avatar
jabez
Opti is your distributor.
Old Apr 6, 2008 | 06:43 PM
Road Agent's Avatar
Road Agent
Old Apr 9, 2008 | 08:39 PM
502SCS's Avatar
502SCS
My 96 just did the same thing today. Driving down the interstate and just shuts off without a sputter. Started after a few then got home with one event of the same and again it restarted after turning off and back on. Now it is in the driveway (thank god) and it will not start. Not even a sputter ... Just spins ... It does have fuel pressure at the rail. It acts just like a dead optispark but NOOOOOO.......
I replaced it 1 year ago with an accel unit... not this job again
Anyway anything else you guys can think of that would do this and is there a good troubleshooting (go down the list) guide posted anywhere for doing a mythotical check of the ignition system?
Old Apr 10, 2008 | 04:22 PM
Lichen's Avatar
Lichen
"hit a lick"? Any codes?
Old Apr 14, 2008 | 09:28 PM
502SCS's Avatar
502SCS
No friggin codes on my car hell according to the scanner my LT4 is perfect...My car started today after sitting for 24 hours. Started it in the driveway let it idle 8-10 min. then died dead would not restart just spin .. good fuel pressure .. ok yea wouldnt hit a lick and generated NO codes.
Now lets say....
If you were left on an island without your code scanner could you make a guess at what a problem might be or do you just like to make fun of a guy who uses terms like wont hit a lick or does not know what an optispark is ( you did read the part where the poor guy just purchaced the car! correct?)... ok I will translate for you ... the guy meant " when I engage the starter the motor or engine (depending on your critical take on which it is) it will not fire on any of the 8 cyl's" Other than the problematic optispark what else would be the likely guess ... Coil? ECM? Gremlins?
Old Apr 16, 2008 | 05:01 AM
jimijam95's Avatar
jimijam95
Thanks for sticking up for me, I bought the car in Atlanta, and I live in Asheville,NC. Called the dealer and all they could say is how sorry they are, yes she's a 15 year old car, but with only 49k on her, I would expect to get more than 3k befofe having to put more monies in her. Again, thanks for your insights, have ordered an autoscanner, will post more after I do a scan.
Old Apr 23, 2008 | 01:27 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I would say Opti also. My 93 z28 done the exact same thing as yours. Oh, I also hear that the accel optisparks cause alot of problems but that's just what I hear.
Old Apr 24, 2008 | 10:25 AM
wfountain's Avatar
wfountain
I hope not I just ordered a replacement from them
Old Apr 24, 2008 | 07:05 PM
DVNCI's Avatar
DVNCI
LOL
You can tell who is from the South in this post, eh?
I knew what you meant.
Old Apr 26, 2008 | 07:12 PM
jimijam95's Avatar
jimijam95
Originally Posted by RUKWKR
LOL
Well, she's in the shop now, no fire, but the GM Junkie has her in his shop, and she'll be fine soon. But I have no good things to say about Buy a Vette.Net
Old Apr 26, 2008 | 08:33 PM
jimijam95's Avatar
jimijam95
LOL
Thanks, nothing wrong in where I live, besides, got the best curves to drive on !!!
Old May 13, 2008 | 12:55 AM
502SCS's Avatar
502SCS
Comfirmed my problem was OptiSpark
Replaced and runs fine now.
On to the rear wheel hub and brakes.. Will be good as new soon
Old May 13, 2008 | 09:46 AM
DVNCI's Avatar
DVNCI
Thanks for the update - I'm waiting on a new Dynaspark right now. Started breaking stuff down last night and I'm hoping this is the fix (pretty sure it is).
To dead 93 LT1 help please
Old Jun 13, 2008 | 10:31 AM
jim_hewett's Avatar
jim_hewett
LOL
Hey that's real Democratic of you...where do you think Bowling Green is in.... NYC?? Just pulling your chain.
Cheers
Check your 6
Old Jun 13, 2008 | 10:42 AM
502SCS's Avatar
502SCS
My car is still running since the optispark change
Old Jun 13, 2008 | 10:53 AM
jim_hewett's Avatar
jim_hewett
jimi...feel your pain...experienced identical problem as your's. My 94 is in currently in the shop undergoing an autopsy. I'm through w that Optispark distributor, OEM, Chinese, or similar. If you can afford it go w the MSD, a US made version. Before you throw money @ your problem check your FP(fuel pressure), water leaks from TB(throttle body) hoses & WP(water pump) and spark @ a plug. You've probably blown diodes in your OS & it's toast. You might have a simple fix...although I doubt it.
Cheers
