So there will be less fun shortly...
What kind of gas mileage do you get in your T/A?
When I played around with the Miniram, I was getting 14 mpg playing around, and 18 grannying. But that is combined with the problems associated with a chopped up 18 year old wiring harness. Not good either.
So the T/A is a different story. It weighs 3450 lbs and gets 11 mpg all the time on 87. I have to run it richer at 12:1 full time to prevent it from knocking.
Since my Vette now weighs 2700 lbs stripped out, I just want it to have decent fuel economy as light as it has become, but I think running premium and the 383 seem to cut the fuel mileage quite a bit.
I'd just want to know if there are any other high performance carbed combos out there that can do better than 15 mpg on a light car. Hopefully so.
Timing and carb set up is very important..Does everything match in your engine??..ie Heads to Intake and such...You realy should get better than what your getting..Come on over and we'll dial it in.....
JMHO
Although I don't think I could handle driving a 4cyl daily after being in the Vette daily for 4 years. You could always build a mild 350 setup built to handle a ton of spray.
Are you running the 650 DP with mechanical secondaries? If so, we used to call it a DP 4 squirter, very little throttle and all four barrels were dumping fuel, unlike a carb with vacumn secondaries. If that's the case...change carbs, you'll see an increase in MPG. Hate to show my age here, but there's also the Qudra puke (as some called it) more accurately Quadrajet. Small primaries and huge secondaries, used alot on older carbed boats, primaries for fuel economy and the huge secondaries for power.Yep, I'm one of those guys that drive a 4 banger daily, and use the vette for enjoyment. Same as above, and that insurance savings can put alot of fuel in the tank!
RACE ON!!!
The Trans Am is another project. Though I still run very good times with it on crap 87 octane gas, it will still get 11 mpg no matter where I'm at.
This wiring harnesses on both cars was quite chopped up from insulation stripped out to just bad connections on some areas so it might be harder to go back to EFI. I could only dream about LSx swaps at this point, but at least that would be with a much never, better harness than before.
RACE ON!!!
