Stock LT1 cam specifications
Old Dec 11, 2001 | 09:21 PM
GlockLT4's Avatar
GlockLT4
Default Stock LT1 cam specifications
I've been trying to find the stock specs and measurements of the LT1 cam in my '94. Anyone have the numbers (.050 lift, max lift, etc....)? I want to know what i'm starting out with, so I know how big the cams are compared to what I have already.
Thanks!!
Old Dec 12, 2001 | 12:35 AM
ASRoff's Avatar
ASRoff
Default Re: Stock LT1 cam specifications (Glock'94)
(this is for a 96) LT1 Intake lift is .447 Exhaust is .459 duration is 205/207 @ .050 The stock LT4 cam is as follows .476/.479 duration is 203/210@.050 :cheers:
Old Dec 12, 2001 | 01:22 AM
Yguy's Avatar
Yguy
At .050" tappet lift.
Int:203 Degrees/.447Lift
Exh:208 Degrees/.459Lift
Not sure of lobe separation, book says"N/A"
As above, this application is for 1995-1997 Vette-Camaro.
This is from my copy of 2001 performance parts catalog.
Suggestions; try a LPE cam or LT4 Hot Cam(if gearing permits),
or call COMP CAMS for their recommendation.
Good luck.
Old Dec 12, 2001 | 01:42 AM
GlockLT4's Avatar
GlockLT4
Default Re: Stock LT1 cam specifications (corvette_bob)
Ok, thanks guys.
I'm going with the HOT cam.. I called Comp Cams and Crane, and they both recommended some nice ones, but they are $360 and were a little too beefy for my daily driver. I can get the HOT cam off of http://www.gmpartsdirect.com for only $200 shipped, and I've head TONS of excellent compliments about it. Plus it works with my LT4 springs.
One less thing to decide on now :)
Old Dec 12, 2001 | 12:39 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
FWIW...Get the cam from Jeff Kopp.
Old Dec 12, 2001 | 07:37 PM
GlockLT4's Avatar
GlockLT4
Default Re: Stock LT1 cam specifications (Vette92)
I ordered late last night from gmpartsdirect. I don't see that Jeff Could have gotten it cheaper than $170. I'll give him a call just to see though, I could always refuse the package.
To Stock LT1 cam specifications
