Installing Headers
Old Apr 4, 2008 | 07:40 PM
bobmarshall's Avatar
bobmarshall
Default Installing Headers
How difficult is it to install shorty headers on a 94 with a 6 speed. I am considering getting a set but don't know if it can be done without a lift or special tools. Thanks for everyone's advice.
Old Apr 4, 2008 | 09:05 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Waste of money, look at your other post on the same subject...
Old Apr 4, 2008 | 09:17 PM
STL94LT1's Avatar
STL94LT1
It's not too hard. Remove the exhaust manifolds and install the headers. Hardest part is installing a few of the bolts and aligning the passenger's side air tube.
Old Apr 5, 2008 | 12:51 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Not a bad job at all took about 8 hours to R&R. Did my long tubes with the car on 16" jackstands.
Old Apr 5, 2008 | 12:55 AM
Eddie & the Cruisers's Avatar
Get you some Pacesetters and you don't have the problem with the air tube on either side. They are cheaper and are ceramic coated.
Love mine.
I might add, they are built better that the Hooker's by far. They have a full length 3/8" thick flange and easier to mount similar to the original manifolds.
Old Apr 5, 2008 | 01:57 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I just installed shorty headers in my 95 auto. Hate to say but I had to remove the catalysts.
There is much more than just the above comments but, it can be done in your garage with only handtools.
I had to say that unless you are in CA (like me) go for long tube headers...I would!
Old Apr 5, 2008 | 07:33 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You already have shorty headers. Waste of time and money.
Old Apr 5, 2008 | 11:03 PM
I wouldn't consider the '94 exhaust manifolds headers at all. The end tubes exit sharper than 90* and the center two tubes are one common opening to the collector and the end tubes are 90* turns into the common collector. The turns are waaaay too sharp for even flow.
The headers sound much much better than the original manifolds and will add some HP and look much better.
To Installing Headers
