Again with the cluster
Now, I sent this out to get fixed and was told the center LCD was bad. This didn't make much sense to me but hey he's the proffesional right? $275 later it still does the same thing so I sent it back to him. It worked fine in his car so he sent it back to me again. Still the same problem.
This is what I've done so far.
At the pin connector
Ohm the grounds D1 and D3 and they zero'd out, so the grounds are fine.
With the alternator hooked up (car running)
C16 and D16 to D1 I get 14.7 volts and the same with D5 to D1
With the alternator disconnected (car running)
C16 and D16 to D1, 12.1 volts and the same with D5 to D1
I'm getting all the right voltages so what would your next step be?
It looks good from here. The battery voltage will drop with the key (and who knows what else) on and the engine (no alternator) off. All I can see is that you need to fill up.
RACE ON!!!
Never seen that before. It almost looks like its keeping time with the firing of the plugs. Almost like a timing light. Good luck with this one. There are many guys that rebuild these, maybe you can email them the clip, and see what they think. It may be something simple.
What sends the signals to the display?? I don't have that answer, but that is the correct question.
The Display is fine, it is getting signals that are garbled.
however, whats not making sense to me is that the voltage readings from C16,D16,D5 and the Grounds are within the range given by the fsm when the key is on and while running. The connections are the main voltage connections.Signal inputs should only interfere with that part of the cluster not the entire cluster so if its the car doing this I would presume that it would be a main signal thats garbled up... since the entire cluster is going crazy.
One by one I have disonnect signal inputs to see what happens and there are no changes in this light show.
Bill
