Camshaft Removal Help???
Old Apr 7, 2008 | 02:03 AM
Car Guy 88's Avatar
Car Guy 88
Default Camshaft Removal Help???
Hello all, I am in the process of removing the camshaft on my 1988 Corvette coupe with a 4+3 trans. I have just about got it out, however here's my problem: I can only get it about halfway out before the front structural piece blocks it, (if the structural member was just a 1/2 inch lower it would clear). I took out the motor mount bolts and tried to raise the engine just a little with an engine hoist but it wouldn't move even a little bit, so what do I still need to losen/remove to get the engine to move upward just a little bit??? Do I need to disconect the engine from the trans???
Thanks for any guidence you can provide
Old Apr 7, 2008 | 06:24 AM
mechguy79's Avatar
mechguy79
This won't help but I'm glad you brought it up. I was thinking of doing a new cam in the car too. Mine is a 1990.
I have never done this, but I think the transmission is supported largely by the "C" beam. You may need to place a transmission jack under it, disconnect the C beam, and then try to maneuver the engine. Sorry I couldn't be more help.
Old Apr 7, 2008 | 11:14 AM
Vic'89's Avatar
Vic'89
Did you remove the motor mount bolts ?
I had the same issue on my 89 when I was removing the Cam.
All I did was remove the passenger side motor mount and jack the motor up 1/2". The Cam then slide right out.
Vic
Old Apr 7, 2008 | 03:23 PM
Car Guy 88's Avatar
Car Guy 88
Default RE: Camshaft help???
I'll try loosening the C-beam, all I need is for the motor to move just a 1/2 inch upwards.
I did remove both motor mount bolts but when I tried to lift it a bit with the engine hoist it still didn't move even a little bit.
Also the heads, intake, radiator, rad cooling fan ,lifters, distributor, headers and all accesories are moved.
Old Apr 7, 2008 | 03:33 PM
STL94LT1's Avatar
STL94LT1
Put a board between a floor jack and the oil pan. It should move fairly easy.
Old Apr 7, 2008 | 04:40 PM
anchami79's Avatar
anchami79
I was thinking it doesn't take a whole lot to move it, especially just a 1/2".
Old Apr 7, 2008 | 05:44 PM
96GS#007's Avatar
96GS#007
Loosening the c-beam is not necessary.
Old Apr 7, 2008 | 07:26 PM
fredk's Avatar
fredk
Just loosen the motor bolts and jack up at the oil pan, use a 2x4 on the jack. Been there, and thats all the room that you will need.
Fred
Old Apr 7, 2008 | 07:29 PM
JimiHendrix's Avatar
JimiHendrix
Dont use a hoist to pull it it...you are probably cocking the engine sideways. . . . jamming it on its mounts. . . . simply put a piece of wood across your oil pan and gently jack it up. If that doesnt work. Put a tiny bit of pressure on the jack. . . and pry lust a little on the mount brackets and mount. That should do the trick
BTW, I replaced my cam too.. . .
Old Apr 7, 2008 | 07:41 PM
fredk's Avatar
fredk
Hey Jimi, can you play the geetar.
Fred
Old Apr 22, 2008 | 01:49 AM
Car Guy 88's Avatar
Car Guy 88
Thanks you all for all your help, the camshaft is out now!!!, I used a crow bar to shift the motor mount around a bit (yes, they were unbolted) and an engine hoist to lift the engine and that did the trick I'm guessing the enigine hoist was just not lifting at a good angle and was jamming the motor mounts, since once I gave it a little pry with the crow bar the engine easily lifted a good 2 inches.
To Camshaft Removal Help???
