Shift Knob: How To Remove?
Old Dec 12, 2001 | 02:20 PM
White Lightning's Avatar
White Lightning
Default Shift ****: How To Remove?
Need to remove the autotranny shift **** on my 89, but all the GM manual says is the unhelpful, "Remove shift ****." How exactly is that done? I know there's some sort of clip in there. Do I simply squeeze a screwdriver blade down there and pry it off? Or is there some sort of catch that needs to be pressed in?
Thanks in advance,
-WL
Old Dec 12, 2001 | 02:25 PM
dgoodhue's Avatar
dgoodhue
Default Re: Shift ****: How To Remove? (White Lightning)
A pair of snap ring pliers will get that off easily, I was able to pry it off with a small set of screw driver the first time I did it.
Old Dec 12, 2001 | 02:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You have the idea, pry the button out with a small screwdriver. Once the button is out you'll see the C-clip.
Old Dec 12, 2001 | 02:28 PM
White Lightning
Cool. Many thanks.
-WL
Old Dec 12, 2001 | 07:21 PM
Black85L98's Avatar
Black85L98
Used my grinder on the kids scissors to make a snap ring tool :D
Old Dec 12, 2001 | 08:24 PM
OcalaGuy's Avatar
OcalaGuy
Check out this post. I took some pictures
http://forums.corvetteforum.com/zerothread?id=185047
Old Dec 12, 2001 | 08:56 PM
White Lightning
Default Re: Shift ****: How To Remove? (OcalaGuy)
Thanks.
After seeing so many answers, I now realize my question needs to be revised. There are actually two parts:
1. How do I get the plastic button off?
2. How do I get the **** off?
Thanks for the answers to question 2. Any help for question 1?
-WL
Old Dec 12, 2001 | 09:13 PM
Admiral Fairway's Avatar
Admiral Fairway
Use a small straight screwdriver. Slide it down between the shift button a and the side of the of the ****. It will pop right off.
Old Dec 13, 2001 | 02:08 AM
BlackRocket's Avatar
BlackRocket
To remove the steel wedge, buy one of those mini-pry bars from the hardware store. 5-6 inches long and about $5. Use the bent / angled end to pry up against the wedge. It will slide right out effortlessly. I tried a screwdriver for about 10 minutes with no success, the pry bar lifted the darn thing out in about 2 seconds!!! :D
Old Dec 13, 2001 | 10:05 AM
dgoodhue's Avatar
dgoodhue
Default Re: Shift ****: How To Remove? (BlackRocket)
You can buy a set of cheap snap ring pliers for the almost the same price. A nicer set of snap ring pliers with few different adapters cost me ~$13.
Old Dec 13, 2001 | 10:40 AM
91BlkonBlk's Avatar
91BlkonBlk
When I tried to remove the ****, it would not turn or come off. Is there something else that needs to be done other than removing the circlip? :confused:
Old Dec 13, 2001 | 11:43 AM
torqd's Avatar
torqd
1st Gear
Hi all,
I just did this last weekend for the first time. A visual depiction really helped.
I used the parts section of the Eckler's catalog. It shows the button and the c-retainer.
Cheers,
Robert
Old Dec 13, 2001 | 08:37 PM
cshuman's Avatar
cshuman
Default Re: Shift ****: How To Remove? (91BlkonBlk)
I have a 91 with an auto and all I had to do after removing the snap ring was pull straight up on the ***. It does not twist. If it won't pull staight up try putting a little WD-40 in there.
[Modified by cshuman, 6:38 PM 12/13/2001]
To Shift Knob: How To Remove?
