Knock sensor question
Old Apr 8, 2008 | 06:30 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Knock sensor question
I'm changing coolant. Can't get the knock sensor's connectors off. Is there something I can't see, or do I just need to yank harder??? The FSM just says "disconnect"....
Thanks in advance.
Larry
code5coupe
Old Apr 8, 2008 | 06:34 PM
Muffin's Avatar
Muffin
If it is the round one squeeze it. There are two "hooks" that hold the plug secure. Squeeze it opposite to the hooks and they will back off enough to clear the sensor. Yanking isn't a good idea.
Old Apr 8, 2008 | 10:23 PM
rocco16's Avatar
rocco16
Thanks, Muffin.
You probably saved me many dollars and much angst.
Coolant is changed.
Larry
code5coupe
To Knock sensor question
