Ignition Help
Old Apr 9, 2008 | 12:45 AM
harleymarkt's Avatar
harleymarkt
Default Ignition Help
i have a 90 c4 6 speed il bout to do a complete tune up plugs wire ignition module cap rotor coil fuel filter. i have a mallory on there now but its 6 years old i have a light hesitation when the gas is applied. i have afr heads a gm hot cam and larger throttlebody,injectors. plus underdrive pullys abd slp runners and a ported and polished intake manifold and upper intake to match the runners and full exhuast i need more spark now ive seen a accel a hypertech and other mallory ignition what the best combo of parts thanks
pics of my set up are here http://forums.corvetteforum.com/show....php?t=1984753
i also want a new intake
Old Apr 9, 2008 | 12:51 AM
Master__Shake_'s Avatar
Master__Shake_
If you need hotter spark, there's something I've heard of that I might suggest. They're called pulse plugs, supposedly able to give a 5 times hotter spark than a traditional platinum plug.
http://www.pulstarplug.com/
Check it out, that might be just what you need instead of replacing your entire fuel ignition system.
Old Apr 9, 2008 | 01:09 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I have my doubts about this, and $25.00 each is not cheap.
I think you should buy a set and tell us how they run on your new motor.
To the OP, check out the FIRST intake, looks stock, but works well on an engine like yours. For the ignition system, stock will work fine, but you may need a small cap dizzy for the new intake.
Randy
Old Apr 9, 2008 | 01:29 AM
Master__Shake_
Randy
I would, except my motor will run well enough with factory plugs. No need to dump money where it isn't needed. :P
Old Apr 9, 2008 | 11:01 AM
CFI-EFI's Avatar
CFI-EFI
First you need to see if you can buy some capital letters for your post. What causes you to make the comment, "i need more spark" (sic)?
Damn! And I left my snake oil in my other wagon. FYI, a platinum plug gives no hotter a spark than any other plug.
RACE ON!!!
Old Apr 9, 2008 | 11:06 AM
bczee's Avatar
bczee
I have always been in favor of using a MSD 6A or 6AL.. it has always help my cars with cams in smoothing out the idle and WOT performance.. (as will as the Mallory and Accel units). the Multi-Spark CD could help you some. ?
Old Apr 9, 2008 | 03:46 PM
harleymarkt
i could buy a new coil module and plugs and wires for the same cost of those "super" spark plugs
To Ignition Help
