1994 C4 Lt1 Intermitant Problem
Old Apr 9, 2008 | 09:30 AM
JJ2000's Avatar
JJ2000
Default 1994 C4 Lt1 Intermitant Problem
hey guys need some help, my c4 is acting up but not all the time, it has to be something minor and tune up related i think, i have replaced the the fuel filter, pcv, and air filter so far, i believe 94 had plat plugs which are good for 80- 100k, my car only has 45k on it, what the car is doing is almost stalling, rpm's get real low almost like its starving for fuel, but only after the car has been started, never does it when its cold and does not do it all the time, and never when your driving or at a light, only when you first start it, giving it some gas clears it up after about 5 sec, i have also done gm top engine clean and fuel injector cleaner, the car sat for 3 years proir to about a month ago when i bought it, could this be a distribtor problem, any ideas out there? thanks guys
Old Apr 9, 2008 | 10:35 AM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
I had similar issues before with both a cracked spark plug and an arching plug wire. Wait till it's dark and take a close look under the hood. You'll be able to see the arching (and possibly hear it) then.
Just a thought.
Old Apr 9, 2008 | 10:49 AM
NEVRL8T's Avatar
NEVRL8T
I wouldn't bank on those platinum plugs lasting that long especially when the pucks come off.
Old Apr 9, 2008 | 11:14 AM
JJ2000's Avatar
JJ2000
yes i agree and even with the age as well, im thinking of doing it all in the near future so its done and prob will fix the problem, plugs, wires, cap & rotor....
Old Apr 9, 2008 | 12:10 PM
HOWSER's Avatar
HOWSER
St. Jude Donor '09
I'd leave that "cap and rotor" alone unless it is failing.
Old Apr 9, 2008 | 12:47 PM
JJ2000's Avatar
JJ2000
yea i dont want to change anything i dont have too, but im not sure where the problem is that why i was gonna do it all
Old Apr 14, 2008 | 11:42 AM
JJ2000's Avatar
JJ2000
at this point looks like im gonna do plugs and wires and not do the distributor since its very pricey, see what happens with just the plugs and wires, any more feedback would be great..thanks guys
Old Apr 14, 2008 | 12:29 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Pull your codes before doing anything.Clean your IAC/ TB passage second. Top end cleaner does nothing for cleaning the TB.
To 1994 C4 Lt1 Intermitant Problem
