possible to use V6 prom w/programming?
Old Apr 9, 2008 | 03:23 PM
kentz's Avatar
kentz
1st Gear
Default possible to use V6 prom w/programming?
I have a 89 ZF/TPI and want to replace the maf ecm with a 730. I only have the prom from the V6 to go in the 730. has anybody tried to use a V6 prom with G1 from moates to run V8 tables/programming? would the V6 prom work for the limp home mode? I should find the schematics somewhere and find out for myself but if anyone knows and has a quick answer it would be appreciated.
presently have the g1 and autoprom on my maf setup. i'm just too cheap to buy another memcal from gm.
best case if i could find another sd/730 V8 car here and plug and play and see if it works. but i don't know anyone here with that stuff everyone plays with honduhs and other rice cookers.
thanks,
kent
Old Apr 9, 2008 | 11:13 PM
mseven's Avatar
mseven
Originally Posted by kentz
I have a 89 ZF/TPI and want to replace the maf ecm with a 730. I only have the prom from the V6 to go in the 730. has anybody tried to use a V6 prom with G1 from moates to run V8 tables/programming? would the V6 prom work for the limp home mode? I should find the schematics somewhere and find out for myself but if anyone knows and has a quick answer it would be appreciated. presently have the g1 and autoprom on my maf setup. i'm just too cheap to buy another memcal from gm.
best case if i could find another sd/730 V8 car here and plug and play and see if it works. but i don't know anyone here with that stuff everyone plays with honduhs and other rice cookers. thanks,
kent
First, I can't even imagine a 6cyl.prom controling fuel and spark properly (based on values/tables etc.etc.) let alone anything else. I also don't understand the need to swap to a SD (727/730) stradegy ecm. I have tuned both types (sd and maf) and can say that I would never take on that type of swap.
A stock prom (sd, 1990-91) shouldn't be that hard to find, if not, you can download a stock bin file from tuner pro site or from moates.net and load (burn) it to a 512 type chip (5.00)since you already have a g1, and this part of it would become a plug and play
(provided of course you can pin in a 727/730 ecm in your 89 for starters).
HOWEVER that would be the easy part, you will additionally need to give the car a MAP, and MAT input to the 727/730 ecm (wiring harness?) in doing this conversion, which your 89 MAF stradegy 165 ecm/car does not have (not to mention possible other wiring/pin issues).
I am not aware of anyone who has done a conversion like this, but you can look around here (scroll down to DYI prom tuning and DFI and ECM): http://www.thirdgen.org/techboard/?
Old Apr 10, 2008 | 11:17 AM
tequilaboy's Avatar
tequilaboy
I'm also curious why you'd want to do a 730 conversion in the first place. What is there to really be gained?
For high HP or forced induction application with a 165 ecm, I'm a fan of the Ford MAF conversion, but as far as I'm aware, I'm the only one running one.
Its fairly straight forward if you know what you are doing.
To possible to use V6 prom w/programming?
