My stock L98 was decked to about .014 the first time it was at the machine shop while it was being punched out to a 383. I didn't have the intake shaved as it never occurred to me to have it done, my machine shop didn't mention it and I had no issues with the intake fitting on the heads.
Now that my builder had to rebuild the lower end for me due to their **** poor math and built me a 12.2:1 compression engine...we are also decking the block again to get my quench area down to the mid .040's. So...should I check for fitment after the heads are back on the block or should I be planning on shaving my intake base regardless, now that the new deck height will be about .005.
As far as the history on my intake base ...I bought it used. It is an Edelbrock high-Flo base.
If there's enough taken off the deck, then some should be cut off the intake side of the head. Any decent machine shop will have the specs as to how much and when. The heads are usually cut so that intakes can be changed at will.
In my logical mind that doesn't seem to be the best option. Those heads would become married to the block. Heads costs more than intake bases, so I would machine the intake. Just my opinion.
I'm with you on that one Dan. I'll talk to the shop when I pick up my shortblock
The amount of material to come off of the intake to head surfaces isn't dependent on what the new deck clearance (.014") is, or what the new quench distance becomes (mid .040's), it is based on the amount of metal removed. As stated above, there are charts and/or formula to tell you how much to remove from where, based on the amount the deck was lowered. Be advised, if the deck was lowered enough, the bottom of the intake will have to be shaved or the manifold can hit the block and keep the manifold from sealing to the heads.
it's called angle milling, my motor had that done on the heads since the deck was shaved and the heads were as well. all in all .050 came off which is why i now need 7.150 pushrods rather than the too long 7.2" ones in the motor now. the risk of not angle milling the head lies in oil entering the intake port from a poor intake seal.
Why are you decking block more if compression is too high? Sounds like you would have to deal with piston and head chamber shape first??
Good question....I had two issues with my motor....I wasn't happy with the quench area which was .054 and my compression ratio was too high. Yes, these two conditions are fighting each other, but both reeded to be resolved. Solutuion....deck the block and add dished pistons(nothing left to remove from the heads)
