Upper Ball Joint Installation
Old Apr 10, 2008 | 02:22 PM
bills1985corvette's Avatar
bills1985corvette
Default Upper Ball Joint Installation
I am about to start installing my upper Ball Joints. A short description of the process would be appreciated. I know you need to drill the heads off the rivets but do you try to drill through the entire length of the rivet or just drill the head off the punch the rivet out? Suggestion on drill size? This suspension rebuild has been quite a job! The bushing and u-joints in the rear went well but I have been fighting the front end.
Old Apr 10, 2008 | 02:42 PM
86PACER's Avatar
86PACER
Drill both heads off and knock the rivet out with a punch and hammer. Removing the heads relieves the clamping tension. If you try to go all the way through with a hand drill, your likely going to go off center and eat through the control arm and not come out centered on the other side. Leaving the rivet hole elongated.
When you install the new upper ball joint bolts, have the nuts and extra threads on the top and bolt heads on the bottom. This prevents hitting the knuckle when you steer
Old Apr 10, 2008 | 05:56 PM
IRAraid's Avatar
IRAraid
Default Upper ball joint rivets
A die grinder or 4-1/4" right angle grinder will grind the heads off very quickly. And if you're careful, won't damage the control arm at all.
To Upper Ball Joint Installation
