Battery Charger Killed the Vette
I went out to start it and of course the battery was so down it barely turned over so I put it on the charger and when I came back a bit later I noticed that I had left the charger switch in the "12-v crank" position.
I tried to start the car, it didnt even try to turn over, but all my lights and guages worked.
I got under it and tested the starter by crossing the terminals and the engine cranked, sputtered, and still wouldnt start. (key was on btw)
It's VATS has been disabled already and i've never had any troubles with the gear selector lockout
I really hope that leaving the car connected to high-amp electricity didnt destroy my computer or (wouldnt doubt it) my ICM *again*
ANY suggestions? I'd like to see the page out of the FSM to troubleshoot if anyone could scan it for me.
Ryan Kemppainen
My .02
The voltage it puts out is still safe for the car, unless you hooked it up reverse polarity it shouldn't hurt the ecm.
David
the battery has a full charge now
remind me again what holes do i cross make the codes flash?
Batteries don’t like to be discharged for extended periods of time. With a used battery with some time on it, there’s deterioration in the cells when un-charged. It can be charged up but you loose that normal performance that enables you pull high current for longer periods of time. It also won’t hold a charge as long in the future. Always keep a wet cell charged. A normal vette had a draw of 30MA due to the computers. That will pull the battery down over a period of time (longer than a month), keep it charged.
Simple stuff first: Make sure the battery terminals are clean and tight. Clean the ignition key with alcohol. On the 93, you can check for codes by connecting terminals A & G. Turn key to on and check for codes. Top right, bottom left (I think).
Simple vats questions
1- Does the fuel pump run for about 3 seconds when the key is turned to ON
2- Measure voltage at starter solenoid when key it turned to START.
This will give you a direction to start in.
If pump runs, vats is probably OK
If voltage at starter solenoid and no action, probably a defective solenoid (starter).
but there is possibilty that you've smoked the ecm...ALWAYS disconnect the vehicle ground cable and install a temporary ground lug to charge...NEVER attempt to start an ecm -equipped vehicle using the "start/boost" mode of a battery charger..."fast" chargers are also murder for electronic dashes, etc. (info courtesy of used car buds who have learned the hard way)
Will not disagree that this is the safest way to do it.
However;
A good battery when charging will keep the charging voltage at a max level even at high current charging is set. A bad battery will allow the charging voltage to rise and not be somewhat capped. Now even if that happens, the electronics should have a tolerance built in of max voltage to it. Even 15 or 17 volts should be with in these specs.
The reason for not charging and starting these modern cars with computer systems is there could be a large fluctuations of current and voltage which could cause large voltage spikes that could damage the computers and anything else which now is connected to the B+ lines now that you have turned the key on. With the key off, only the computers are always connected to B+ still, but there is no voltage fluctuations from the battery or charger.
Since I believe that crkemppainen did not try to start the car with the charger connected, I don’t think he could have not damaged anything (besides, it never cranked) .
If the solonoid/starter can be jumped to turn the engine, then there is enough power for a normal start. If this is true, then troubleshoot normally why it won't turn over under or start.
I bought a chiltons manual by the way and it is about worthless.
tomorrow i'm testing the ICM
Since the fuel pump is running, VATS is probably not an issue. We were discussing the no crank problem. Why are you focusing on the ICM when it does not turn over, or are we past that point. If you cant crank, see if you can measure any voltage on the solenoid when you turn the key to start. Possible bad starter or start relay. Hopefully not ignition switch.
How do you plan to test the ICM. Its basically a 5 to 70 volt amplifier that drives the coil and has its input from the ECM. You can not check it with a meter, but only in an operational connection or by substitution. If you want to peruse this, I have a lot more info on this if need be.
VATS kills the injector pulse not the fuel pump. Ryan. Check your VATS bypass. With key off. Remove bypass, wait 10 minites reinstall bypass then start your car! I do this every day just try it, You have nothing to lose
David
I stand corrected on the fuel relay in regard to VATS.
VATS, or called Pass Key will disable the injectors better known as FEDS (agreed). The point I really wanted to make was in regard to the start inhibit relay. If VATS is triggered it will also not allow the start relay to close not permitting voltage to be applied to the solenoid on the starter. That is why I wanted it measured to see if there was any voltage at the solenoid to see if it was bad. If VATS goes active there is a 3 minute time out.
Thanks, Paul
David
be back later today
David
