problems with 89 instrument cluster!!
Old Apr 11, 2008 | 08:16 AM
darryl1969's Avatar
darryl1969
2nd Gear
Default problems with 89 instrument cluster!!
hello all, I'm a newbe to this sight but glad I found it! I have an 89 corvette and about 2 months ago my cluster started getting possessed on me! speedodometer, tach and gauges going crazy.have replaced the tach filter and old cluster but with no luck. could it be the ignition coil or maybe but hopefully not bad wiring? would appreciate any comments on this!! luck not to good right now plus cant tell fuel gauge either! thanks. darryl1969
Old Apr 11, 2008 | 11:51 AM
80vetteuga's Avatar
80vetteuga
Check your grounds, they will [lay havic with the cluster. Had the same problem - it was a poor ground.
Old Apr 11, 2008 | 12:57 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
check: www.batee.com for digital dash info and problem solving & using the search/advanced/archives features will definately help
Old Apr 11, 2008 | 02:02 PM
darryl1969's Avatar
darryl1969
2nd Gear
Default thanks so much
it was the ground on the ignition coil!! if anyone has this problem please check this first!! will save 400.00 !! on new cluster.
Old Apr 11, 2008 | 02:05 PM
89vette's Avatar
89vette
I'm having a similar problem with my tach in my 89. Where is the coil grounded?
Old Apr 11, 2008 | 03:39 PM
WW7's Avatar
WW7
If your having trouble with just your tach then it is probably your tach filter. It will jump all over the place or sometimes not work at all when the filter goes bad..WW
To problems with 89 instrument cluster!!
