400 Small Block?
Old Dec 12, 2001 | 10:56 PM
KYVette90's Avatar
KYVette90
Default 400 Small Block?
How well do all of the accessory brackets and other stuff bolt up to a 400 block? Are there any problems commonly run into when putting all of the stock stuff on the 400 block?
Old Dec 12, 2001 | 11:08 PM
Chris@SD's Avatar
Chris@SD
Default Re: 400 Small Block? (KYVette90)
The heads are going to present the problems, but that is easily solved with a drill and tap!
Easy work. Any engine shop should be able to handle something like this.
Good Luck,
Old Dec 13, 2001 | 02:09 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Felpro has a new gasket that is supposed to help with cooling issues of the 400 block. It was in the latest Chevy High Performance.
Old Dec 13, 2001 | 02:17 AM
drive it's Avatar
drive it
Default Re: 400 Small Block? (AquaMetallic94LT1)
Only other major issue is the harmonic balancer-if you don't get an aftermarket small diam. (no I didn't!!) then you'll have to cut a notch in the front frame rail to clear it. PIA if you don't figure that one out till the engines in and you press on the balancer!!!!
Old Dec 14, 2001 | 06:31 PM
No Go's Avatar
No Go
Haven't explored the problems associated with the swap but your 90 has a one piece crank seal-so the crank, oil pan, flywheel, etc won't change over.
I know it has been done and seems a perfect choice...
To 400 Small Block?
