How to replace antenea on 85 vette?
Old Apr 12, 2008 | 04:52 AM
85L98-84L83's Avatar
85L98-84L83
Default How to replace antenea on 85 vette?
My antenea wont go up. How do you get at it from underneath? Is it a big deal to change?
Old Apr 12, 2008 | 05:15 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Reference FSM, again, will all the different posts, its time to get a FSM or learn to use the Search, Advanced, Archive posts function. You'll find your answers and alot of good info this way... 99% of the questions asked have already been said and answered before...
Under = Yes
Deal = No
2 options - mast replace ment or new unit
or could just have broken wires
Old Apr 12, 2008 | 07:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
After diagnosis and you have confirmed that removal is required, pull the wheel and inner fender.
http://members.shaw.ca/agent86/power...a%20wiring.pdf
http://members.shaw.ca/agent86/Power%20Antenna.pdf
Old Apr 12, 2008 | 07:31 AM
85L98-84L83
Thanks agent86, nice reply, not like some
Old Apr 12, 2008 | 07:59 AM
AGENT 86's Avatar
AGENT 86
What the hell are you doing up so early, said the early bird.
Old Apr 12, 2008 | 09:33 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default A little short "cut"
One trick is to just cut the wire going to the relay under the back hatch trim panel and splice the new wire onto it. There is a rubber grommet that the original wire goes through near the antenna motor that is a real pita to get the wire through. I spliced mine there and saved alot of time and headaches.
Old Apr 12, 2008 | 12:35 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
I replaced mine with a Harada from Mid America. It was a breeze. It comes with detailed instructions. You can also download the instructions from MAM's site and see if it is something you want to tackle. I did not splice a single wire.
Old Apr 14, 2008 | 04:02 PM
85L98-84L83
I'm from the kootenays, I will give you one guess...
To How to replace antenea on 85 vette?
