Replace Oil Pressure switch - 91
Old Apr 12, 2008 | 12:02 PM
djrammer's Avatar
djrammer
Default Replace Oil Pressure switch - 91
1991, L-98 motor, auto trans. Looks as though I may have an oil pressure switch leaking. Oil on left rear side of block, below switch. It's starting to run down the side of the block also.
The way the switch is tucked in there, how hard is it to change??
What size is the switch?
Thanks,
Dewey
Old Apr 12, 2008 | 02:06 PM
CFI-EFI's Avatar
CFI-EFI
Thanks,
Dewey
Medium large. What do you mean by "What size is the switch?"?
It isn't too hard to change. It will be more accessible if you remove either the distributor or the windshield wiper motor.
RACE ON!!!
Old Apr 12, 2008 | 06:50 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Maybe it's just the OPS, but these L98s have a common problem with the rear manifold leaking after almost 20 years. Did the rear seal on my '90 a couple of years ago. Story here:
http://jacnsue.com/Corvette/Repairs/Intake_reseal.htm
But maybe you'll get lucky
Jac
Old Apr 12, 2008 | 09:55 PM
johnnyevans's Avatar
johnnyevans
Pull the 3 wire plug out of the sender/sensor, if there's oil on the inside of the plug on the sender, it's sender time.
The rear of the manifold is bad about leaking.
You need a very deep well 1-1/16" socket to take the sender out without removing the distributor.
Old Apr 13, 2008 | 07:47 PM
djrammer's Avatar
djrammer
Thanks guys.
I have a sneaky feeling it's the intake rear seal leaking.
Old Apr 13, 2008 | 10:01 PM
Radco10's Avatar
Radco10
I just did this last week on my 91. Check out post 5 to this thread: http://forums.corvetteforum.com/show....php?t=1992858
To Replace Oil Pressure switch - 91
