Rear Gears
Old Dec 13, 2001 | 12:58 AM
dmalhi1's Avatar
dmalhi1
Default Rear Gears
just wondering about my cars gears i have no idea what the mods are really just was wondering about my gas mileage again.. its kinda high in my opinion compared to a buddies vette which is much more power ful than mine but burns less fuel....... either way i heard on the forum that it might be my o2 sensor or even my rear gears...... ok well someone told me on the forum that i should drive my car up to about 65mph and get the reading on the tach..... well ok you techies! i was running 65mph in OD at about 17-19 RPM..... do i got stock rear gears? oh and this is the 1988 Coupe.
thanks
davin
Old Dec 13, 2001 | 01:55 AM
vader86's Avatar
vader86
Default Re: Rear Gears (dmalhi1)
sounds like the 3.07's to me
Old Dec 13, 2001 | 03:53 AM
Hutch's Avatar
Hutch
Yep, those should be the 3.07's, not 2.59's. Check your RPO codes to see if your car came with the 3.07 performance axle ratio, option G92.
Interesting... you're running about the same RPM as my GS coupe at 70mph but it has 4.10 gears (and a six speed, of course). ;)
Old Dec 13, 2001 | 05:29 AM
dmalhi1's Avatar
dmalhi1
Default Re: Rear Gears (Z06VERT)
ok so is that a good thing? :confused: yeah i'm not very vette savvy in the technical division :lol:
but is this the reason i might be using up so much fuel aswell ? and wheres the build codes?? under the lid of the console right? ok i'll check later on tomorrow.
thanks guys...... i still dunno what 3.07 rear gears mean though.... whats it do compared to this 2.59 that is stock for the 88 ?? hope i'm not bugging ya in getting you to inform me.
any replies are highly appreciated.
thanks again
davin
Old Dec 13, 2001 | 06:20 AM
cohocarl's Avatar
cohocarl
For the moment, I have 2.73's in my 85 auto, and at 70mph the tach reads 1900rpm, so it does sound like you've got 3.07's. I hope to have 3.73's in mine in the spring..... I drive my Cavalier Z-24 5-speed for the mileage, the Vette for smiles, and my wife's Dodge Stratus R/T 5-speed for a little of both. (I hate to admit it here on the forum, but her Dodge is a blast to drive on a nice tight road.)
Later,
Carl
[Modified by cohocarl, 7:59 PM 12/15/2001]
Old Dec 13, 2001 | 09:45 AM
chucks88's Avatar
chucks88
Default Re: Rear Gears (cohocarl)
My '88 came with 2.73 stock and I am at 1900 rpm's at 70 mph. I am however picking up a new rear this weekend with 3.07. I not planning on any higher gear ratio with my stock cam.
Old Dec 13, 2001 | 10:27 AM
Goody's Avatar
Goody
Default Re: Rear Gears (chucks88)
dmalhi1 - To be as simple as possible, the rear gears act as a torque multiplier for your engine. The trade off is loss of high end speed. We can all thank CARB for not having the option to select our own gear choice at the dealership. Why do I need 2.59 gears??? Who can go 172mph in this country?? Would rather have had 3.45 or 3.73 as an option. :crazy:
Old Dec 13, 2001 | 11:31 AM
vader86's Avatar
vader86
Default Re: Rear Gears (Goody)
lower gear ratio, higher number, means youre quicker off the line but you lose the top speed as he said. Gas mileage should not be a major problem, i get an average of 19mpg with mine and have the 3.07's. I still get better mileage than every SUV on the road.
Old Dec 13, 2001 | 03:57 PM
CFI-EFI's Avatar
CFI-EFI
Torque multiplier? yes! And a speed reducer. Lower (ratio) gears have higher numbers than high gears, which are lower numerically. Among other things, your rear axle gears reduce the drive shaft speed, by the amount of the ratio, to the output to the wheels. The torque is multiplied by that same ratio. Four to one is a lower gear than a three to one. With 4:1 gears, the wheels turn at 1/4 (25%) driveshaft speed. And the input to the rear end torque is multiplied by 4. Three to one gears only drop the wheel speed to 30 percent of driveline speed, and multipy the torque by 3. Higher gears equal reduced engine rpm at a given driving speed. Lower gears provide greater torque muiltplication for quicker acceleration. There is a lot more to this, but these are the basics.
Old Dec 13, 2001 | 04:00 PM
scorp508's Avatar
scorp508
Too much gear for L98, go no more than 3.45 and you will be smiling. :)
Old Dec 15, 2001 | 01:54 AM
dmalhi1's Avatar
dmalhi1
ok my cars lil console sticker doesn't say G92 but says G44.... now at the same time i am confused cuz i ran my vin (yes i finally found it) that i found on the console lid with the RPO codes and well carfax says my cars got 4 reports i gotta see and that its not an 88....... its an 89..... now.... my car is a rebuild they say..... so maybe that center console box isn't the one thats supposed to be there or something? maybe its from an 89 and the sticker is to another car? i dunno i'm confused either way lemme know if G44 is a RPO Code for 3.07 gears aswell.
Old Dec 15, 2001 | 01:59 AM
vader86's Avatar
vader86
G44 is the 3.07's. Its that way on mine as well, i dont have G92 performance ratio but still have the G44 3.07's. I dont trust Carfax reports anymore either, since it was wrong in my cars case.
Old Dec 15, 2001 | 06:25 AM
dmalhi1's Avatar
dmalhi1
Default Re: Rear Gears (vader86)
ok cool thanks vader
(please don't say you're my father) :D
To Rear Gears
