Battery will not hold a charge
Old Apr 12, 2008 | 11:00 PM
doctorstork's Avatar
doctorstork
Default Battery will not hold a charge
Brand new battery will not hold a charge. Is it the alternator
Old Apr 12, 2008 | 11:15 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Could be the alt. or a draw in current somewhere.Charge the battery off the car and see what it does and go from there.
Old Apr 12, 2008 | 11:16 PM
65Z01's Avatar
65Z01
Look at the voltage reading after startup; it should jump into the 14+Vdc range and settle back to mid 13+Vdc range after charged.
If this happens then something is likely discharging the battery after the engine is shut off.
Old Apr 13, 2008 | 01:01 AM
jfb's Avatar
jfb
More likely you have excessive leakage current (battery current with ign off). At night check for underhood lights, vanity mirror lights, door map lights, center console light, Do you have a radar detector, CB, aftermarket alarm, aftermarket radio or audio amplifier, GPS, check em. Remove the negative battery terminal and connect an ammeter from the cable to the neg battery terminal and after the courtesy lights time out, switch your ammeter down to lower scales and measure the current. GM says leakage current should not exceed 50 milliamps, my 87 draws 27 ma. If you do have high leakage, pull the courtesy fuse, then watch the ammeter while you pull fuses one at time to see if you have a sudden drop in leakage. Further investigation of that circuit will then be required. Also, when you ask for help, state what year C4 you have, they are not all alike. Be sure to recharge your battery with a charger overnight or for a full day, batteries left discharged become door stops.
Old Apr 13, 2008 | 10:23 AM
c4cruiser's Avatar
c4cruiser
Did you have the battery load tested? Take it to a reputable shop and have the test done, they will charge the battery and test it. It will be easy to tell if the battery is good or not.
What is the battery voltage with the negative cable removed? If voltage is around 12.1 or less, the battery is probably toast.
Even if the voltage display on the dash shows 14v or so with the motor running, the battery could still not be taking a charge. 13.8v to 14.5v or so indicates that the alternator is producing a sufficient amount of power but if the battery is not being charged from alternator output, the alternator can eventually be ruined.
Checking for a current draw will have to be done if the battery checks out as good and the alternator is generating the proper voltage range.
You do need to post the year of the car too.
Old Apr 13, 2008 | 10:38 AM
jfb's Avatar
jfb
Partial Quote from C4cruiser"
That is completely false! If the alternator is not supplying current to the battery, then the only current the alternator is supplying is that to the car which it does normally. Normal alternator current won't ruin an alternator!
Old Apr 13, 2008 | 10:40 AM
Iroc57's Avatar
Iroc57
When you say will not hold a charge do you mean once the car sits overnight it will not crank or when you stop to gas up it won't restart?
Old Apr 13, 2008 | 11:13 AM
Can86Z51's Avatar
Can86Z51
Sounds like what happened to me, last year, when a 2 year old Delco died on me - would not hold enough of a charge to re-start the Vette, even after a boost, then re-charge. Turned out to be a dead/shorted cell! Battery was toast!
Old Apr 13, 2008 | 04:53 PM
JonnyAngle's Avatar
JonnyAngle
On my car, the bolt that attaches the battery cable to the side post was stripped. Check that out too.
Old Apr 14, 2008 | 12:02 AM
86PACER's Avatar
86PACER
Old Apr 14, 2008 | 07:40 AM
pcolt94's Avatar
pcolt94
This is what ran thru my mind also, what is the time frame. Also, is it a brand new battery like you got it last week and why did you initially change it.
Good piece of information along with the others. My 94 draws about 29-30 ma and can sit for weeks with no problem. If you measure about 14 volts when its running its probably charging. If it won’t hold charge for a day, then there’s a current draw or new battery is bad perhaps.
Old Apr 14, 2008 | 07:53 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Get a 12V test light. Take off one of the battery cables. Put the test light in line between the battery and the loose cable.
If the light goes on, you have a draw killing your battery.
Old Apr 14, 2008 | 08:06 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Unplug both power seats. I fought this problem for about 5 years, and one day while in the car working on it I heard a little sound that turned out to be the power seats trying to move. Even if you just sat there very still, car off, they would try to move a little then stop. I unplugged it and never had a problem since. Car sat all winter and started it this spring with no problem!
There is a process you can go thru to identify the circuit that is causing the problem. But if you get lucky you can try the seat plugs...I have heard they are prone to this problem...even in newer cars today.
Old Apr 14, 2008 | 10:21 AM
Demonic85's Avatar
Demonic85
The voltage will get weaker as you drive and will eventually shut the car off it were the alternator. On a brand new battery I would suspect a draw. Check your headlights for draw as well. Interior lights are a pretty common draw as is the radio.
Old Apr 15, 2008 | 01:13 PM
doctorstork
1991 standard coupe...thanx for detailed response...I appreciate your help and the help of everyone who responded so quickly
Old Apr 15, 2008 | 01:16 PM
doctorstork
it did drop suddenly with driving and died 400 yards from home.
Old Apr 15, 2008 | 10:01 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If it died like that it is the alternator. When the car is running, what does the gauge say? I'll bet it is only charging at about 6 volts. That happen to me the first day I owned my current vette. A new alternator will fix you right up, don't forget to charge the battery w/ one of the cables disconnected from the battery. The ECM does not like battery chargers.
Randy
To Battery will not hold a charge
Old Apr 15, 2008 | 11:48 PM
jfb's Avatar
jfb
If your alternator is not charging the battery the red battery symbol light on the dash will be lit. Also, your voltmeter will read below 13 volts. Normal operation is for the voltmeter to read 14.3 volts engine cold and this will drop as the alternator warms up until it reaches 13.3 volts. The dash voltmeter reads in error and low with the engine not running.
Old Apr 16, 2008 | 08:00 AM
Iroc57's Avatar
Iroc57
Randy
It is a simple swap
Old Apr 16, 2008 | 03:11 PM
jfb's Avatar
jfb
Partial Quote from RandyJ75:
You do not have to remove a battery cable to charge your battery. Your alternator does the exact same thing to your battery that a battery charger does and it doesn't harm your ECM.
