C4 passanger power window
Old Apr 15, 2008 | 04:28 PM
Laurensdad's Avatar
Laurensdad
8th Gear
Default C4 passanger power window
Got a 1984 C4... passanger power window travels completely to the up position but travels down and stops about 2 inches above the door/window sill. Is there an adjustment for this. It does not appear as if something is blocking its movement.
Any help would be greatfully appreciated
Old Apr 15, 2008 | 04:38 PM
jhammons01's Avatar
jhammons01
The regulator may have a broken "ribbon"
Check out the threads under "Regulator" to see if this meets what you are experincing
Old Apr 15, 2008 | 04:40 PM
Square's Avatar
Square
The early C4's (up until late 1986 models) have a different window regulator than the later models. While there is a stop point that can be adjusted, it is common for the early regulators to simply not be strong enough to properly raise and lower the window (the ribbon becomes dirty, old, or broken as mentioned).
The door skins are usually old and fragile and to adjust the stop point (if it is the issue) you will need to do 80% of the work required if you just replaced the regulator. The newer regulators are much faster and smoother and can be had on ebay much cheaper than the GM retail price (GM wants about $300 each I believe).
I have replaced my driver's side regulator, and I would not pull the door skin on an early C4 without replacing the regulator. It is a serious improvement!
Old Apr 15, 2008 | 04:46 PM
jhammons01's Avatar
jhammons01
well before you tell him to hunt on ebay, check out this thread
http://forums.corvetteforum.com/show....php?t=1941533
Old Apr 15, 2008 | 05:04 PM
Square's Avatar
Square
True enough.
My bad.
I should have mentioned to buy one of the official GM "sealed in the bag" units. They are still much cheaper than going to the dealer.
Old Apr 15, 2008 | 05:34 PM
skybolt31's Avatar
skybolt31
The 84's, 85's and 86 coupes had the ribbons, the 86 verts had the new type. I had an 86 with the ribbon and when it broke, I put a new ribbon in. If I had it to do over and could get a newer type unit like the deal from Corvetterecycleing, I would definitely spring the $99 to upgrade.
Old Apr 17, 2008 | 11:35 AM
Laurensdad's Avatar
Laurensdad
8th Gear
Hey Guys....Thanks for all your responses really good stuff.
I'll check the ribbon more closely but from what I can see seems ok.
I may end up upgrading to a newer unit.....
Thanks again you Guys ROCK
Old Jul 15, 2010 | 10:57 AM
chuckeb84's Avatar
chuckeb84
or buy a local door as I did...for 100 new glass and upgraded regulator work grrrrrrrrreat!
Old Jul 16, 2010 | 01:01 AM
HlhnEast's Avatar
HlhnEast
I have to agree with one of the posters in the link that J provided tho. There is a difference between "replacement" and "upgrade" I probly woulda made the same mistake. Just read the listing carefully and look at the pics. You have good reference photos to look at here if your not sure.
To C4 passanger power window
