crank pulley removal
Old Apr 15, 2008 | 05:35 PM
Demonic85's Avatar
Demonic85
Default crank pulley removal
I've never had a problem with this before but I cant figure out a good way to remove the pulley. The 2 methods I normally use dont work: putting my foot on it or sticking a screwdriver into the flywheel. Any tips?
Old Apr 15, 2008 | 06:21 PM
CFI-EFI's Avatar
CFI-EFI
The flywheel is at the wrong end. Remove the three bolts holding it to the damper and the single bolt from the damper to the center of the crank shaft. If the pulley doesn't fall off, a light rap with a hammer or prying with a screw driver will remove it.
RACE ON!!!
Old Apr 15, 2008 | 06:25 PM
Demonic85's Avatar
Demonic85
Yeah but I cant get the center bolt out, its just turning the whole engine. Isnt there a way to hold it still?
Old Apr 15, 2008 | 07:24 PM
Demonic85's Avatar
Demonic85
Got another problem, the water pump has an extension pipe coming out of the side and I guess you're supposed to remove it and install it on the new pump. I need a new one since I rounded it off and its still stuck on there. I dont understand why GM designed it this way, makes no sense.
Old Apr 15, 2008 | 07:26 PM
Swift_Striker's Avatar
Swift_Striker
when I did it the other day I put a wrench on one of the outer three and held the wrench with clockwise force while I took the middle one out. Then the outer one was easy to come out, didn't need the force but if you need force you can use this technique on all the bolts till the last one of course, then if it's still stuck, good luck
Old Apr 15, 2008 | 07:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I insert the three long bolts from a puller and use a lever to hold the crank shaft so I can loosen the center bolt.
Maybe you can get the WP extension piece from a bone yard.
Old Apr 15, 2008 | 07:39 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Put a socket and ratchet on the bolt and wack the ratchet handle with a big hammer. Usually the shock will loosen it enough for normal ratchet removal.
Old Apr 15, 2008 | 07:43 PM
Z51L9889's Avatar
Z51L9889
If the car has a manual trans, put the trans in gear and set the emergency brake. That keeps the crank from turning so you can get the bolt loose.
Another trick I've used in the past (not on the Corvette, though) sounds REALLY strange, but it actually worked. Take the serpentine belt and wrap it around the crank pulley pointing down so it is laying on the ground. Pull the belt to the side of the car until it's tight then stand on it while you try to break the bolt loose.
Old Apr 15, 2008 | 08:01 PM
86PACER's Avatar
86PACER
What trans?
Mine's an automatic and I did mine like this. I used a wrench on one of the flywheel bolts by letting it wedge itselft agains the exhaust in order to hold engine stationary. Then I loosened crank bolt with breaker bar. When reinstalling, I put the wrench under the exhaust pipe to hold engine the other way. Worked good. Held it hard as a rock. Flywheel bolt never even budged.
If that don't work you can use a chain wrench if it's got enough chain to wrap around the pulley. Cushion the teeth with a piece of old belt.
With one of these babies, if you can get it around something, it will hold it. Most only come with enough chain for a 5 inch pulley. I need to buy a chain extension on mine. The handle is plenty long though.
Old Apr 15, 2008 | 08:15 PM
Demonic85's Avatar
Demonic85
Thanks Swift, worked like a charm
Old Apr 15, 2008 | 08:42 PM
racebum's Avatar
racebum
strong impact gun also works
Old Apr 15, 2008 | 08:59 PM
Demonic85's Avatar
Demonic85
Yep had no problem removing the harmonic balancer after that, had some oil come out of the hole though
Can I use a 1" threaded nipple (yes plumbing) for the water pump? I cant find anyone that sells replacements.
Old Apr 15, 2008 | 09:18 PM
AGENT 86's Avatar
AGENT 86
Yes.
My local parts place sells the nipple in chrome plated(TransGo), if chrome is your thing.
Old Apr 15, 2008 | 09:21 PM
Demonic85's Avatar
Demonic85
Originally Posted by AGENT 86
Yes.
dont know about chrome but thats good to know.
Old Apr 15, 2008 | 09:28 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Silly me. I would just leave the belt on while I broke the 4 bolts loose.
Old May 22, 2008 | 01:31 PM
Grrrrandpa's Avatar
Grrrrandpa
Brilliant idea! Worked like a charm on the outer three bolts while holding the center bolt. This way is safe as the torque spec. for the middle bolt is 75 lb. ft. and the spec. for the outer bolts is only 60 lb. ft.
Not as safe for removing the inner bolt as it has a higher torque spec. than the outer ones, so holding an outer one while removing the inner one will over-torque the outer one.
Old May 22, 2008 | 01:32 PM
Grrrrandpa's Avatar
Grrrrandpa
You've obviously never had to remove the harmonic balancer ...
Old May 22, 2008 | 01:44 PM
anesthes's Avatar
anesthes
On the stand. You won't fit a gun in there. Crank is like 2" from the front cross beam.
First engine swap in a C4 I put the crank pulley on after engine was in. Never make that mistake again. Second engine pulley went on while on the stand, then the motor in the car. what a pita.
-- Joe
Old May 22, 2008 | 05:46 PM
JAKE's Avatar
JAKE
i've even used the starter to break the bolt loose. 6 point 1/2" socket, breaker bar with long piece of pipe slid on the end of the bar. BUMP starter and the bolt loosens.
Jake
To crank pulley removal
