remove drivers seat question
Old Dec 13, 2001 | 04:58 PM
asr off's Avatar
asr off
Default remove drivers seat question
I need to remove the drivers seat so that I can re-install the plastic brake handle cover that has become loose because the screws in it have vibrated out. (and of course the screws in the cover face the drivers seat)
Can someone tell me how big a job this will be ?
Thanks in advance. :cool:
Old Dec 13, 2001 | 05:16 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: remove drivers seat question (asr off)
I may be wrong, cant' recall, but I think all you have to do is remove the seat cushion, not sure just a guess????????
:cheers:
Old Dec 13, 2001 | 06:15 PM
tdock's Avatar
tdock
Remove the bottom seat cushion, there is a small wire clip in the bottom front of the seat, just push that down and back then up through the opening and the cushion will lift right out, then if there are just four bolts that hold the seat frame to the slider/adjuster, remove them and pull out the plastic frame. And if needed four bolts that hold the adjuster to the floor. I think they are all 12mm bolts.
To remove drivers seat question
