fan on @ 193/194
Old Apr 18, 2008 | 09:42 AM
dwblindref's Avatar
dwblindref
Default fan on @ 193/194
Hi 'Vetteheads,
I need some assistance with the fans on my '95 LT-1 'vert.
Background, I have owned and sold a '93 6-speed and a '96 LT-1 that were as stock as dirt. The fans would run and then shut off as normal, hot, but normal.
The '95 'vert w/49k miles has the fan come on @ 193/194 and stay on. The temp stays @ 193/194, but that dang fan is driving me nuts.
The previous owner said that the previous owner may have put a tuner in the car, or he may have changed the thermostat, or he may have changed the relay, or he may have done all of the above.
How do I determine if a Tuner was installed?
Without taking out the thermostat, how do I determine if it has been changed.
How do I determine if a lower temp fan relay has been installed?
Thank you all for your information, I'm lost here.
Dave @ 954-240-2822
Old Apr 18, 2008 | 07:37 PM
86PACER's Avatar
86PACER
Thermostat can't control fan activation. Don't bother pulling it.
Old Apr 18, 2008 | 08:02 PM
CFI-EFI's Avatar
CFI-EFI
And there is no such thing as a "lower temp fan relay". A relay is just a relay. A switch activated by power from a remote source. In this case the computer. Programming is the cause of your early fans activation.
RACE ON!!!
Old Apr 18, 2008 | 08:43 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You can have a tuner change the program or learn how to do it yourself. You also may have something like a Hypertech chip.
Old Apr 18, 2008 | 09:18 PM
STL94LT1's Avatar
STL94LT1
You can "Read" the PCM with TunerCat or LT1 Edit software, this will tell the fan's on/off settings.
It sounds like the PCM has been reprogrammed to run a 160* thermostat. But, currently it's running a 180* stat that won't allow coolant temps to get low enough to deactivate the fan(s).
To fan on @ 193/194
